Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom Fabrication from 3D CAD to YOU!
Old Mar 4, 2009 | 10:11 PM
epsmotorsports's Avatar
Ok here is the deal, I am putting together some parts and tools in 3D CAD and I am going to take these drawings to a machinist for production. What I would like from everyone are Opinions and Ideas. For example: I will be designing a Strut Tower Brace, what would you guys like to see added or removed to STB's you have seen on the market already. Do you prefer round tubing or a squared tubing? 2pt or 3pt? Also things like aftermarket intakes? Special Tools? Things that only one company makes and charge a ton for?
I would like to get these made for as cheap as possible but of an acceptable quality, and in turn sell them to Third Gen Owners at the lowest price possible.
Lets hear some ideas.
Also I will be searching old threads to see what the most popular are.
Old Mar 4, 2009 | 10:19 PM
Stephen's Avatar
Car: 87 GTA
Re: Custom Fabrication from 3D CAD to YOU!
I wanna see a new pair of taller strut mounts, with the bases having integrating STB mounts in them, instead of separate mounts. Make sense?
Old Mar 4, 2009 | 10:32 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
that is exactly what i would like to see also.
something like this. the braces would have to be adjustable length though so you could change camber and caster
Old Mar 5, 2009 | 08:34 PM
Do you have any other pictures of that stb you posted. I will work on creating something similar.
Any more ideas.
Old Mar 5, 2009 | 09:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
A different plenum for the HSR to fit under firebirds and vettes and possibly a slight taper to the rear cylinders for better air distribution
Old Mar 5, 2009 | 09:37 PM
Stephen's Avatar
Car: 87 GTA
Any more ideas.
The mounts for these....
integrated into these....
I have a stock mount & the UMI piece, but it would be nice to have them as one piece.
Old Mar 5, 2009 | 09:56 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I rack and pinion to stock k-member. That works
Old Mar 6, 2009 | 06:13 PM
Transmission: t5
no i don't have any other pics i just found that on another site sorry
Chuck84TA
Members Firebirds
29
Jun 30, 2017 08:47 PM
Ingram78
Fabrication
17
Jul 29, 2015 06:54 PM
Gibson27
Aug 1, 2011 09:05 AM
tacman444
Fabrication
Aug 17, 2010 08:21 AM
