Custom TBI - TPI air intake conversion
Car: 1992 RS Camaro 25th Aniversary
Engine: 5.0 TBI V8
Transmission: 5 speed manual
This is still somewhat in prodution because...well I wasnt quite sure what to do with the vaccum line and other things that would connect to the stock intake. Anyway heres some pics of what I came up with.
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
Re: Custom TBI - TPI air intake conversion
its different... but i kinda like it. i auctually thought about doin something like this on my 89 rs... ive never had any expirence with a tpi so here comes a noob question... wheres the air filter????
Engine: 5.0 TBI V8
Theres two air filters that are square and they go inside the Y shaped TPI intake on each side
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
it looks like an elephant has his trunk over your carburator
Car: 1991 Camaro RS vert.
Engine: 305 TBI
Transmission: 700R4 Auto
Looks pretty good. I did something very close to that on my 91 TBI. I purchased the carb/tb hat at a local parts store itw as around 60 dollars. the rest was just stuff i had on hand and the factory Z style aircleaner box, I have since apinted the PVC and hooked the Air sensor into the air box and so on. it all works and funcutions. I no longer lose power once the motor warms up and starts sucking down Hot air form the open element i use to have on it. Good job. Keep updating if you make changes.
Pics near bottom of this thread if your interisted. https://www.thirdgen.org/forums/tbi/...filter-vs.html
-Randy-
-Randy-
Car: 1984 Trans Am
out of curiosity, can you use a dual snorkel setup from an earlier L69 HO car on the LO3?
Car: 88' Iroc-Z
Engine: LQ9
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I actually did I different setup... I bought a spectre single carb plenum and then ran it out the side down the a 90 4" aluminum to a straight pipe then drilled out the old carcoal cannister location and ran a filter externally... I take some pics when i'm all done so you guys can see...
Engine: 5.0 TBI V8
Oh by the way just to say how I made it...I used some sculpting foam (hard foam you can shape easily) then I used a fiber glass kit from my local hardware store and made the black fiberglass carb...hood...thing and the rest is really junk yard stuff two air intake tubes from random cars that fit and the TPI intake.
Car: 1989 Camaro RS
Engine: 305 TBI
I like it. Does it plumb out air that would normally go through your radiator, though? It kinda looks like that's where it's coming from, behind the grille. I was going to change my intake, but that nice big cylidrical air filter housing has grown on me. I'd at least leave that in.
Engine: 5.0 TBI V8
Engine: 5.0 TBI V8
By the way I have made a change to it...not a big one but I wired the stock intake temp sensor for the TBI to the stock intake sensor for the TPI...I dont know that it did anything performance/running wise but it makes it feel more complete :P ill get pictures later
Car: 91 rs vert
Engine: 305 tbi
I thought I was the only genious to do this. Actually I haven't done it but it is on my list of mods I wanna do. Good job. If I get enough money to do it I'll take pics n post them here.
Engine: 5.0 TBI V8
This setup probably only cost about $50...If there's a junkyard near by you, you just need to find some intake tubes that will fit, a TPI intake, then go to your local hardware store (ex. HomeDepot) and get a fiber glass kit that comes with fabric and the appoxy stuff. After that its just making a mold for the fiber glass and putting it together. Some problems I ran into though was you need a new place to route the valve cover breather tube, I got lucky and one of the intake tubes already had a hole that lined up perfectly...and also you need to plug off the vaccum line that went to the cold start butterfly. Also I believe that it actaully limits the air flow to the engine because when I first put the system in the idle was high. It should adjust itself after a little while. Well I hope that helped at all with your budget. I know how it goes I have a very limited budget too and most of my car is junkyard parts, but goodluck and please do post pictures Id love to see others Ideas.
Car: 91 rs vert
Engine: 305 tbi
Hey! All I need is the tpi air box and my set up will be done. I've already ordered it but as soon as I get it in I'll post pics. Did you put in a spot for the iat?
Engine: 5.0 TBI V8
Thats great! What is the iat? If it has something to do with air intake temp sensor then yes I did. I got a long wire, cut the old sensor out and attached it to the old sensors wires and ran it to the new one in the TPI box. It was fairly easy to do.
Car: 91 rs vert
Engine: 305 tbi
i hope this works. i cant figure out how to post pics on this so i put a link.
http://photos-d.ak.fbcdn.net/hphotos..._5698000_n.jpg
Engine: 5.0 TBI V8
Yup works for me... Nice job! Looks clean. What did you use to connect the intake hood to the TPI? Looks like a plastic to me.
Car: 91 rs vert
Engine: 305 tbi
im not too sure what your talkin about but i think youre asking what i connected the tpi air box to the carb hat? i pretty much jist used specter products. but way to expensive. the whole set up was about $150 maybe even more.next i plan to put this
http://www.hawksthirdgenparts.com/ca...mairboxes.aspx
i hope it helps.
i hope it helps.
1992 Trans Am
May 10, 2023 07:19 PM
