Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
switch panel mount
Old Jul 9, 2009 | 03:41 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
switch panel mount
i got a longacre start switch panel from ebay and couldnt figure out where to put it then my cousin and i just thought of this. we mounted it in the the ash tray location. it fits perfectly just needed to cut out some plastic. i like it. what does everyone else think about it?
my original plan was to put it in the center console but i didnt really have a good way to mount it without spending any money.
Old Jul 9, 2009 | 04:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: switch panel mount
looks a bit R!cer to me
Old Jul 9, 2009 | 04:28 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I think it would fit right in if you would blend it in with dark paint.
you can't cut up the panel instead?
Old Jul 9, 2009 | 04:50 PM
92whiteta's Avatar
Engine: 355
i could cut the panel but i dont want to. i might paint it black with the bird on it. not sure yet but im glad i found a home for it.
Old Jul 10, 2009 | 04:30 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Sorry dude, It looks like an eye sore.
Old Jul 10, 2009 | 06:53 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
it does stick out quite a bit, maybe if you had some more color matching parts in the interior it wouldn't be quite as bad...
Old Jul 11, 2009 | 09:17 AM
92whiteta's Avatar
Engine: 355
yeah, i have been looking at it and i think im gonna paint it.
Old Jul 11, 2009 | 04:15 PM
92whiteta's Avatar
Engine: 355
ok i got it painted. it looks a whole lot better.
Attached Thumbnails switch panel mount-07-11-09_1612.jpg   switch panel mount-07-11-09_1613.jpg   switch panel mount-07-11-09_1614.jpg
Old Jul 11, 2009 | 04:52 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Thats not so bad now that it's painted. Doesn't look NEARLY as out of place as it did
Old Jul 11, 2009 | 05:11 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
looks luch better.
Old Jul 11, 2009 | 06:29 PM
Pocket's Avatar
Car: 91 Trans Am
Why not make one? Its not hard
https://www.thirdgen.org/forums/fabr...anel-lots.html
Old Jul 11, 2009 | 07:03 PM
92whiteta's Avatar
Engine: 355
Originally Posted by Pocket
im lazy and i like how mine is set up
Old Jul 11, 2009 | 08:29 PM
HCR13's Avatar
Car: 1987 Trans Am
it does look alot better... you should go ahead and paint the radio trimm aswell...
Old Jul 11, 2009 | 09:20 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
is it actually hooked up or is it just for show.. i installed a push button start from pepboys into my buddys 85 iroc the other day and put it in the cig lighter.. works perfect was about a 15 min install and works better then the key did.. still need the key to turn fuel pump on tho so with out u cant steal it... what are the other troggle switches hooked to ?
Old Jul 11, 2009 | 09:43 PM
92whiteta's Avatar
Engine: 355
im doing the wiring on it tomorrow. the first switch on the left is ignition power, then the start button, fuel pump, and cooling fans on the right. i would paint the radio trim but it is broken, i have to fix it first... not very high on my to-do list lol
Old Jul 11, 2009 | 11:35 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah...I would suggest wiring up "everything" to work from the switch panel. Honestly, IMHO, I don't think there is a point to wire up a push button ignition and still have to put the key in. The reason I would put a push button is to get rid of the key in the first place so I think it would be a waste of time to put the key in, turn the ignition, then press a button... Something I would like to do in the future is get one of those Flaming River proximity cards that turns on the ignition when you're near (its a card that you can leave in your wallet or key chain) so all you have to do is push the button to start and go...
Old Jul 12, 2009 | 10:00 AM
92whiteta's Avatar
Engine: 355
all the key will do is unlock the steering wheel.
Old Jul 12, 2009 | 01:13 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, but if you're butting the key in, why not just continue and turn the crank? When I get another car, I'm going to put the push button start on it but I'll figure out a way to dispose of the key completely. I'll probably drop the steering column to see what needs to be done to leave the steering loose and shifter aswell...
Old Jul 12, 2009 | 01:21 PM
92whiteta's Avatar
Engine: 355
it takes .8 seconds to put the key in and turn it. im not worried about losing that kind of time.. not quite that lazy... i want the start button because i think its cool.
Old Jul 12, 2009 | 02:27 PM
HCR13's Avatar
Car: 1987 Trans Am
I know what you mean (thats why I got remote start) but I'd like to get a whole different ignition start system that what came in these cars. What I'd love to do is completely disassemble the key ignition plate/drum/etc (I forgot what its called) where key goes in, and leave an empty hole there in the steering column, and then add the "Engine On" button in that hole. I haven't looked heavily into it yet since I don't have a spare car I can use as my mule. Like I said, the only thing I can think of is using the proximity card or that kind of system. So I don't even have to flip any switches. As I approach the car, all the little bells and whistles turn on (including fuel pump) so all I have to do is get in and push "Engine Start" button and go... Good luck on your install, let us know how it turns out...
Old Jul 12, 2009 | 03:15 PM
92whiteta's Avatar
Engine: 355
that sounds cool.. wish i had the time to figure out something like that.
Old Jul 12, 2009 | 04:39 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I don't think functionality was a real big factor.. you just wanted to look like a race car
Looks good man, but seriously why? Also just looks a little out of place to me.. But hey to each his own.
Old Jul 12, 2009 | 05:11 PM
92whiteta's Avatar
Engine: 355
yeah it was more looks cool but it will function
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Dialed_In
Aug 20, 2015 01:45 PM
