Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welding in roll cage rear plates near gas tank
Old Aug 20, 2009 | 12:17 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
This is actually on a 4th gen using the wolfe cage. Think its safe enough to weld in the floor plates without dropping the tank out? Fuel lines are main concern since they are plastic and fearing they could melt but not sure if they are really close to the floor back there.
Old Aug 20, 2009 | 04:43 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Re: welding in roll cage rear plates near gas tank
You might want to try that in a 4th gen board or LS1Tech. As far as I know all of the third gen lines are metal. Also (I'm not soliciting professional advice, this may cause you or others to be burned, maimed, or killed), if you can pull them from the body a bit maybe you can put a wet rag around them?
I should add that there was a thread on here a while ago where someone light a carpet fire and completely destroyed their interior while welding on subframe connectors.
Old Aug 20, 2009 | 11:48 PM
Pocket's Avatar
Car: 91 Trans Am
Pull the tank/lines
3rd gens burn carpet when welding SFC's, 4th gens burn fuel lines and LS1 cars melt plastic tanks
Dont be stupid, just pull it and do the job right
Old Aug 25, 2009 | 09:40 PM
bonebrake22's Avatar
Car: 89 Iroc
Engine: none yet
Transmission: TH350
Axle/Gears: strange 33 spline 4.30
JB weld......jk. Don't chance starting your car on fire. I think a person would be able to be more focused on good welds without the idea in the back of their mind of their car going up in flames. Hopefully that makes sense. Just my 2 cents.
Old Aug 26, 2009 | 09:07 AM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Originally Posted by Pocket
Pull the tank/lines
I've seen youtube videos of this
Old Aug 27, 2009 | 10:14 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Big deal
This guy IS welding his gas tank
Completely safe too!! He's using 4x4s and not 2x4s to hold it up
Attached Thumbnails welding in roll cage rear plates near gas tank-gastankman.jpg
Old Sep 11, 2009 | 12:56 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Originally Posted by Arizona IROC
Big deal
hahaha must be in mexico too
4th gens have plastic tanks lol why are we even discussing this?!? 3rd gens are metal and would be safer but ive heard of some nasty fire ***** due to vapor from the tank while welding... i pulled mine to a safe 6-10ft from where i was welding after i pumped the full out. 3rd gen tanks are pretty light empty actually
id pull the tank, i did when i did mine... the 3rd gen tank is something like 1/2" from the trunk floor steel. my dad acutally cut a 8" line in his when cutting a door to get to the fuel pump lol he didnt realize it was that close.... that car scares me
Old Sep 11, 2009 | 01:11 AM
Pocket's Avatar
Car: 91 Trans Am
Actually a full tank is less dangerous than an empty one as the vapors are the explosive bits
Assuming you used a cutoff wheel, how did you manage to cut 1/2" down into fuel lines? The point of small high speed tools is the extra control and precision. If you whack it 1/2" or 1/4" beyond what you're cutting you have no business with it
Old Sep 11, 2009 | 02:06 AM
Car: 87 TA clone
no he cut a 8" line into the top of the gastank. when i looked at mine the tank was maybe 1/4" from the floor pan. thats pretty close, u would figure it would be farther down. as far as him having no buisness with the tool, sometimes he scares me but in his defense the tank is pretty darn close to the floor and not knowing how close the tank is can be an easy mistake.
yea i know the vapor is the bad part but i wanted it empty so it would be easier to install back up... it was about half full which added quite a bit of weight.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
