Looking for misalignment Inserts for (LCA's/PANHARD)
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Anyone have a link to where i can buy some to work with this style rod end http://www.summitracing.com/parts/HAL-XMR12/ while keeping the rod end center in both the panhard and lac brakets?
Re: Looking for misalignment Inserts for (LCA's/PANHARD)
The panhard brakets are 2" width and the lca's brakets are 2.5" width, right?
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
doesn't spohn sell these?
Car: 1987 IROC-Z
Transmission: TH350
Spohn does sell them... they have eveything you'll need
http://www.spohn.net/shop/Replacemen...ngs-Coil-Over/
Car: 1987 IROC-Z
Transmission: TH350
UMI sells the offset bushings for the LCA's too...
http://www.umiperformance.com/catalo...jit0v304cspon7
Too spendy. UMI i will go with if i cant find a diffrent set thanks for the link and help tho
Car: 1987 IROC-Z
Transmission: TH350
You could always buy aluminum stock and machine it down to get a custom offset. If you have access to a lathe, this would probably be the cheapest.
Otherwise you could probably take the metal to a machine shop and they could probably do it cheap.
Yet another option is to take the metal to a tech school. Talk to one of the shop teachers and see if you can get it cut. Sometimes they'll do it for free because it is a good learning experiance for the students. If for some reason they aren't in spec you'll probably only lose ~$5 in material costs.
Just my $0.02
Mike
Just my $0.02
Mike
yea thats what i was thinking too just pick up some stock and turn it down. alot of time invold tho. Great idea on the school. . .
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
24bux is too spendy? you will not find them cheaper. Even if yoiu try o make them yourself. Just buy them and be done.
or check out these people, but i dont know if it will be cheaper
http://www.midwestcontrol.com/
not UMI spohns . . .
Hello,
We can also sell the ones that keep the rod end centered in the mount rather than off set. They would be $6.00 per rod end
Hope that helps!
Ryan
Hope that helps!
Ryan
Gunner242
Dec 25, 2015 04:49 PM
