Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel tank to floorpan clearance?
Old Sep 25, 2009 | 05:49 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
anyone have an accurate measurement?
i want to modify my sending unit to take a 90deg bulkhead fitting to properly supply my fuel pump.
i was going to cut a hole in the hatch, but i dont want to hack up the car if i dont have room.
ive found several threads and a few pics, but clearance looks blind by the pic.
http://www.jegs.com/images/photos/30...361-983310.jpg
going to use that fitting, then make a flare on a piece of tubing and run it to the bottom of the tank where the pump used to be for a pickup.
any help is appreciated.
maybe a member has already done this.
thanks.
Old Sep 25, 2009 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fuel tank to floorpan clearance?
i think stephen posted a pic a while back, you have something like 3/4 to and inch from the floor to the tank. I dont think a 10an 90 will fit, but maybe you could fad up a recessed spot in the sending unit to make some room? I assume you will have to modify the stock setup anyway.
Old Sep 25, 2009 | 07:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
was going to grind off all the stock lines and englarge the holes.
if that doesnt work i can drill a new hole.
will need to get a -10 for a pickup, -8 for return, and another -10 for a vent.
ive talked to one guy that says i can feed from the stock lines no problem for my hp, but everyone else in the world says i need a -10 or dont bother.
Old Sep 25, 2009 | 07:58 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
If your worried about it you could space the tank out with some rubber grommets or maybe rubber hose.
That way you could use the stock straps but just not tighten the nuts down all the way.
Old Sep 25, 2009 | 08:56 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
that may be an option!
you have given me an idea.
if there is a 1/4 inch of room there now, then my idea is useless.
but, if there is 3/4 or so there, and thats not quite enough, ill just loosen the gas tank straps until i can put a piece of metal back flush with the hatch floor.
still would like to get an idea of how much clearance is there before i go dipping into something i cant fix.
thanks for you post.
Old Sep 25, 2009 | 09:59 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
how much hp are you running. I thought -10 was huge for a supply. i thought that -6 was could feed up to a 450hp motor and -8 was like 650 or so.
I might be wrong but iirc -10 is huge.
Old Sep 25, 2009 | 11:12 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
640-650 crank hp.
i have spoke with my carb guy, aeromotive, magnafuel, and also glens performance on a variety of pumps from a big race piece to a walbro340. all of them recommend that it needs a -10 supply for my application.
-10 is huge, BTW.
Old Sep 26, 2009 | 07:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hell im only running a little over 500 fwhp and i have a 10an feed and a 8an return line. I just figured go big now so i dont have to re-plumb it all again in a year when i change my mind with the car and swap in a bigger motor. Its the 3rd complete fuel system ive had in a year, so i didnt want to mess with it anymore. So im good up to 1500 N/A horse
Old Sep 26, 2009 | 09:04 PM
Pocket's Avatar
Car: 91 Trans Am
For that big its time to sump the pan
AN10 is 5/8" ID
Old Sep 26, 2009 | 09:18 PM
Stephen's Avatar
Car: 87 GTA
And here it is again.....
Old Sep 27, 2009 | 08:48 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
did you mod the stock tank?
pics?
thanks!
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thank you for the pic, thats almost accurate.
looks like 15/16" of an inch, but its hard to tell.
concur?
Old Sep 27, 2009 | 09:12 AM
Pocket's Avatar
Car: 91 Trans Am
Keep in mind the floor has ridges and the tank isnt flat
Also think about the plate you're putting over it all. It will sit ontop of the floor so your new max height is to the top of the old floor or roughly 1"
Old Sep 27, 2009 | 09:54 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
not trying to thread jack or anything.
but what are they ratings of the different - fittings?
also to hook up a -10 fitting to the stock tank i have to assume that you would not even use the stock sending unit. or do you have to completely remove it and basically remove all of the piping the add new piping into the tank also.
this thread has me thinking.
Old Sep 27, 2009 | 11:52 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
pics?
thanks!
no, improtant side note i forgot to mention, its a Nasty Performance fabricated aluminum sumped tank, 1/2" npt outlets.
Old Sep 27, 2009 | 02:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I'm running -10 but with a sump. -10 is the minimum that magnafuel calls for with my pro star 500 pump, they actually state a -12 would be better if I needed that much fuel volume. Sure is nice to never see a pressure drop at the hit off the line anymore. I would imagine you could skip the sump and just drill a hole in the bottom like is used for 4th gen tanks but you will have to race with 1/3 tank or slightly more all the time. They just use a typical fuel cell bulkhead fitting in their plastic tanks. I wouldn't run the 3/8" line unless I had a high pressure pump to keep up with, if you're running a carb pressure pump then your advice is sadly mistaken.
Old Sep 28, 2009 | 08:16 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
wish i had the room for one, (and the money).
if i did a sump, id have to redo my exhaust setup.
Old Sep 28, 2009 | 08:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
could cut the stock lines, redrill, or drill a new hole and make my own feed line.
still need the fuel level to function, so im going to have to work around that as well.
my buddy chris got back with me and said he did the same thing to his 02ss(plastic tank) and a -10 bulkhead fit.
looks like the route i might take.
going to wait till the last Q/S race of the year. prolly turn into a november or december project depending on the weather.
it only gets cold here for a week or two. i might just keep driving it and not worry about going faster... right now. hahaha.
Old Sep 30, 2009 | 06:04 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
I'm not trying to hijack, but are we all agreeing that there is about 7/8" of clearance? The only reason I ask is because I am thinking about routing my return line up there.
Old Sep 30, 2009 | 08:32 AM
Stephen's Avatar
Car: 87 GTA
You act like everybody is arguing about it, despite with the PICTURE already posted above....
Old Sep 30, 2009 | 01:02 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
I never said anyone was arguing about it, I was just trying to get an answer to the question, since stage 20 asked the same question in an above post, and no one answered him. In fact, his opening post asks for an accurate measurement, which is what I too was trying to get.
As for the picture being posted, they often help but are sometimes deceiving...stage 20 read it as 15/16", i read it as 7/8". I was just trying to get a clear, and as was asked of before, accurate measurement. Some of us want accuracy, others can live with just ballparking it and say "Oh, it's around an inch or so". I appreciate the picture you posted, but I was just trying to get an accurate measurement, just like the o.p.
Old Sep 30, 2009 | 01:11 PM
Stephen's Avatar
Car: 87 GTA
Well, the pic is at an angle (can't get a 100% direct side-on shot) but if 1/16" inch concerns anyone for clearance (in the planning stages) for something like THIS?
Old Sep 30, 2009 | 04:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if a 1/16 of an inch will make or break you, scrap the idea
Old Feb 23, 2010 | 10:22 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Has anyone done this, fit a return or vent fitting at the top of the tank?
Old Feb 24, 2010 | 06:48 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i still dont know if its possible, but i am going to try it here in the next couple of weeks.
got a sumped tank, and im going to plumb a larger return and vent. try anyway....
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
