Fab up ram air intake for carbed 350
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Hey guys I have a 4bbl 350 and I'm going to get the ram air hood but I wanted to know if there was any way to get that intake to wrk on a carb
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fab up ram air intake for carbed 350
anything is possible, you would either have to pan the hood over to the carb, leaving a hole for the aircleaner to stick through, and build a box around the carb to isolate it from the engine bay. Anything is possible, just requires some planning and some fabrication.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
http://www.jegs.com/p/Spectre/Spectr...03412/10002/-1
saw this and thought it might be interesting.. if you have a ram air hood
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
A little over a year ago I fabbed up a sheet metal plenum to fit on a buddy's TBI Camaro so he could hook up the TPI Y-pipe intake. It was pretty cool looking. It looked alot like a mini ram. I don't have it or any pics anymore though. It was very, very easy to make once I had all of the hood clearance measurements. I'm going to make one for my car one of these days but in a little different style. It mounts to the top of the carb/TBI just like a regular air cleaner and it's held on by the wing nut.
Car: 1987 Trans Am
Engine: 5.0
Thanks for the info guys.. I like the one from JEG's... but I think I am going to fab one by grafting two stock filter boxes. I think its going to be easy, and with a hi-flo filter, it should work good.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
