Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Weight?
Old Sep 29, 2009 | 10:44 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Weight?
I own a 1989 camaro rs ttop. I'm wondering how much my car weighs. anyone know how much the car weighs without all the added options then give me the weight for all the options so i could add up how much it weighs?
whats been done.
[removed]
- spare tire & jack removed
- whole ac system out
- steel rs "flat" hood
- 1 snorkel air cleaner
[added]
- indy 500 "fiberglass" hood
- open air element 14x3
- sub box w/ 2x 10" subs & x1 amp
Old Sep 29, 2009 | 10:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Weight?
Find a truck scale and drive across it. There are way too many option packages to give a rough estimate. An RS is a lot lighter than a Z28 but it's still impossible to give a weight guess. It could be anywhere from 2800 to 3600 pounds.
Old Sep 30, 2009 | 09:41 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Weight?
where are those normally located? i live in ct... an are they free?
Old Sep 30, 2009 | 12:10 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Weight?
At your local garbage dump, or a junkyard. Yes, they are usually free, unless you are unloading garbage while you are at the dump.
Old Sep 30, 2009 | 07:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Weight?
Garbage dumps have them, most junkyards have them. You may be able to find a self weigh scale along a highway. Most industrial parks and truck stops have pay scales for trucks to use. Even some trucking companies have their own scale.
I weigh my car every spring to see what the season's race weight will be after the winter projects. I use a pay scale and it only costs $10. I drive the front wheels on the scale and stop until it takes a reading. Drive the whole car on and get a reading. Drive off and stop with the rear wheels on the scale and get a reading. The front and rear weight should equal the total. Doing it this way tells me what the weight ratio is of the car. Mine is still nose heavy with 1800 on the front and 1300 on the rear. A good weight ratio for a drag car is 50/50. The only way I could do that would be to cut out the firewall and move the engine back about 6".
Check your local yellow pages. You can also try asking truckers where a free scale might be.
Old Oct 2, 2009 | 10:43 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Weight?
My '89 IROC with T tops weighs 3440 give or take depending on how much gas it has and some handtools in the back. It's a 305 TPI auto car.
Yours might be 31 or 3200.
Old Oct 2, 2009 | 10:52 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Weight?
The subs have probably offset the stuff you've taken out. Probably right around stock weight.
I've always wondered if T-tops made the car weigh more or less.
Old Oct 2, 2009 | 11:40 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Weight?
on the plus side that prob help redistribute weight to the rear
Old Oct 2, 2009 | 11:41 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Weight?
More
Old Oct 2, 2009 | 01:55 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Weight?
seen these specs given for '82 z with and without t-top
cars were both CF/auto/4whl disc:
hardtop-3440
t-top-3480
so looks like t-top adds about 40 lb
Old Oct 2, 2009 | 07:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: Weight?
Don't know if it helps, but I still have my sticker on the door of my 1992 RS - states GVWR of 3414. The car was a 305 TBI A/C and T-Top (Lexan tops) with 16in rims.
Old Oct 3, 2009 | 08:57 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Weight?
If you have any road racers or circle burners around, see if they have a set of scales... I have a set of 4 wheel scales and pads... For racers, it sure does make chassis tuning a lot easier. Conneticut has a bunch of racers and race shops, might want to check with them. Doubt it would be free, but the information is great for reference...It will give you total weight, front and rear weight, cross weight and many other things to ponder and use as a tool!!!!
Old Oct 15, 2009 | 02:18 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Weight?
thanks this all helps alot!
just got a new hood and its steel sadly, but i love it since its a 4" harwood bolt on cowl
just wish i could get a full aluminum 427 make things so much easier. by the way, where and how do i do the conversion for coolant & washer tubes? i heard i could put them in the front nose or something?
Old Oct 18, 2009 | 11:21 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Weight?
When my car was nearly all stock weight wise besides the spare tire being gone I weighed in at 2050lb FAW and 1450 RAW.
Since then I have removed the a/c stuff, converted to electric fans, electric cooling pump, I have light weight corvette heads in the machine shop and waiting to get them back and I am in the process of moving the battery in back.
I wonder what all that will do...
Old Oct 19, 2009 | 02:10 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Weight?
what year?
Old Oct 20, 2009 | 12:48 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Weight?
My car is an 85.
Old Nov 16, 2009 | 11:10 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
Re: Weight?
How the hell did you get your z28 2050 lbs!?
Old Nov 16, 2009 | 11:42 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: Weight?
thats just the "front axle"weight,combined weight is
3500
Old Nov 17, 2009 | 07:37 PM
Engine: 350 Tpi
Axle/Gears: 3.08
Re: Weight?
Ohhh i got ya! haha i was like holy hell that car is SOOO light!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
