Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom Shift Lights? Whats yours like?
Old Nov 4, 2009 | 09:47 AM
IROC_U's Avatar
Car: 1991 Z28 Camaro
Engine: 355 sbc
Axle/Gears: 4.10
Hey im just tryin to figure out how i want to install a shift light in my 91 Z28, anyone have in custom shift lights? Lets see some pics!
Old Nov 6, 2009 | 07:06 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Re: Custom Shift Lights? Whats yours like?
I would be very much interesting to see one. I have seen some BMW with 6 speed lights on the shift ****. I was hoping I can find an aftermarket shift light on the ****.
I found a website that shows light on the ****. Not just BMW.
http://www.mustangbodykit.info/stick-shift-*****/
Can't find one for a Fbody.
Old Nov 6, 2009 | 09:40 PM
85_ZED28's Avatar
Car: '85 Z28
I just posted mine in the custom mods thread, here's a video and pic:
Old Nov 21, 2009 | 04:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Originally Posted by 85_ZED28
I just posted mine in the custom mods thread..
I saw that on the custom mods thread and I love it!! I've been wanting to do that to my Camaro. Do you have any pics of the install or a writeup? I think I can figure out the wiring of the display, but what I haven't been able to come up with a solution for is how you tell it what gear you're in? The only thing I've been able to think of is a set of micro switches mounted to the tailhousing of the trans that the shift lever trips to signal which gear you're in. But I think the mounting brackets would be a real pain to fab. Any info on that would be very much appreciated.
Old Nov 25, 2009 | 07:06 PM
85_ZED28's Avatar
Car: '85 Z28
Thanks! Here is a pic of the micro switch arrangement I came up with. The plate is mounted to the base of my hurst shifter.
I programmed a microcontroller to determine the selected gear from the switch inputs, as well as act like a shift light.
Old Nov 26, 2009 | 07:50 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Thanks for the pics. I hadn't thought of using levers to actuate the switches. I was hoping to avoid using a microcontroller though. How hard was it to program?
Old Nov 27, 2009 | 04:09 PM
85_ZED28's Avatar
Car: '85 Z28
Not hard, but it all depends on your experience with them.
You could also use logic ICs to figure out what gear your in, and just modify an aftermarket shift light to get your "shift" signal.
Old Nov 28, 2009 | 07:55 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
That's the problem. I have no experience with them. Its one of those things that I always wanted to learn, but never had the time. With some of the other things I want to do with the dash as far as electronics and gauges its starting to look like I need to take the time to learn though.
Old Dec 14, 2009 | 11:16 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Not my idea, but it worked well. This pic was taken before I buttoned everything back up so excuse the mess.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
