Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
reverse light project
Old May 9, 2010 | 04:50 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
going to convert the stock reverse lenses and integrate them into the sequentials. want to have functioning reverse lights, so im thinking i can mount reverse lights from another car into these end panels that hold the tag lights...
it will need to be small and mounted close to the bottom left to clear the socket/wires from the tag light
any ideas/suggestions/comments welcome!
Old May 15, 2010 | 11:47 AM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Re: reverse light project
I already converted my reverse lights to sequentials and really like em. If I ever get harrassed about it I will need to do this.... so hope you come up with something that looks nice
Old May 15, 2010 | 04:52 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
you dont "need" reverse lights in texas
Old May 17, 2010 | 01:33 PM
V8ReiMeR88MaRo's Avatar
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Here I worked somethin up of what it would look like just incase you think it'd be tomuch and waste a pair.
This is what i plan on doing with mine, I dont have the grids though.
Size:  39.7 KB and maybe rig up some sort of Reverse light in the little recessed area towards the gfx
Old May 17, 2010 | 01:51 PM
Stephen's Avatar
Car: 87 GTA
He's right. Legally, Reverse lights are not required, not even for the State Inspection. Also why I converted my Reverse to red, using Testors Translucent Red, to tie them into my Sequential Turn Signals a couple of years ago.
I got a set of these (the white lights) to use as Reverse lights, after seeing them on a truck, but have never installed them. I get just fine without any, so I'm not willing to cut into my bumper to install them yet. They pop into a rubber "gasket" that holds them virtually flush. Only the rubber gasket piece that they fit in, is out farther than the body & only because of the rubber lip of it. The "gasket" comes in black, but I painted mine white to blend in with my white GTA.
http://www.cmtruckbeds.com/pages/sk_model.html#
Old May 18, 2010 | 11:08 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
if you had an extra set of reflectors, you might be able to cut them up and "weld" or epoxy them to another reflector set, then all you would have to do is get another lense to get the clear part out of. I'll have an extra set of reflectors available if you need them.
Old May 19, 2010 | 04:02 AM
Car: 1986 IROC-Z28
hhmm Ya im not trying to cut into my bumper either. good idea though, thanks!
you know of any companies that make those style lights in miniature versions?
Originally Posted by ericjon262
if you had an extra set of reflectors, you might be able to cut them up and "weld" or epoxy them to another reflector seth, then all you would have to do is get another lense to get the clear part out of. I'll have an extra set of reflectors available if you need them.
hm those reflectors are pretty big...i dont think there would be enough room to fit it in with the tag lights. thanks though.
hhmm..or maybe since my led tag lights light up 3 lanes of highway..i could sacrifice one and use that area as another place to try and mount something. im just throwing stuff out there
hmm or some clear front sidemarkers..with one of my bright *** leds. could cut those to mount em flush and come up with a bracket similar to the front.
Cleotiz
Jan 6, 2018 08:56 PM
deracer
Apr 11, 2016 12:04 AM
Rakim_RS25TH
Sep 1, 2015 04:07 PM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
Omega
Aug 10, 2015 12:46 PM
