metal ramps
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
metal ramps
I have some metal H-beam that I want to make some ramps out of. They are 9"X10ft. I am looking for some ideas from those of you who use ramps and think the best way to do this would be. I have torch,band saw and mig welder so making them wont be a problem if I have an idea to go with. Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: metal ramps
Those are probably way to heavy and overkill for simple ramps. The ramps to load my car onto the trailer are only made from 2x2x3/16" angle iron and are only 6 feet long.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: metal ramps
Yes they would be overkill for trailer ramps. I was hoping to build some ramps to drive the car up on to where I can work on the underside.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: metal ramps
My 2 thoughts:
1) Make them have a smaller angle that standard store bought ramps - with my car 1" lowered, I have to use the hump in the driveway entrance to get my car front on ramps.
2) Make them higher at the top than store-bought. I'm ALWAYS wishing I had even just another 4 inches of space under there! Never understood why with the invention of the lightweight but strong plastic car ramps that they couldn't make them 8 inches longer and at least 2 inches taller. Maybe I'm just getting fat in my old age?
Car: 87 GTA
Re: metal ramps
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: metal ramps
That is what I am trying to avoid,the ground effects hitting. I guess I will take the iron and block it up to get the right angle and height. Does anyone know how high to get front up so if I want to use this ramp to pull motor and trans out from top side at the same time?
Car: 87 GTA
Re: metal ramps
If you are going to pull the engine out the top, you won't want it on ramps at all. The higher a car is, the harder it is for the hoist to get the engine up & out.
My stepped version worked great when the car was at stock height. Now that the car is lowered, all I really need to do is extend the bottom layer, which I've been doing by laying another board in front of the ramps, for the tire to get up on to, to clear the ramp "stops" at the end.
But since my car is so low now, laying under the car my chest hits the car (and I'm skinny), meaning there isn't really any room to work. So the car needs to be higher to work under it. So I'm going to add 2 longer sections to the bottom of the ramps.
Car: 87 IROC L98
Re: metal ramps
With the car in the garage, to lift it high enough to work under, I use 8 ton jack stands on the rear just for the height. The small stands work well under the front a-arms but with 32" tall rear tires, the small jack stands are almost maxed out with the tires on the floor. I also made a jack extension so when the jack is all the way down, the lifting pad just fits under the diff so I don't have to jack it up in stages.
There's no way I could drive into my garage onto any sort of ramps.
As mentioned above, to pull an engine, you don't want it on ramps. I jack mine up to disconnect everything then put it back on the ground to pull the engine. The only way you could easily do it with the car on ramps is with some sort of overhead hoist. Your typical engine crane will have a hard time lifting the engine up high enough.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: metal ramps
I normally leave my cars on the lift when pulling/installing a motor. I remove a front tire, and go in from the side with the engine hoist. With the lift I can raise or lower the car as needed, and even get it lower to the ground if all 4 wheels are off.
I don't know that I'd try to do it with a car on ramps either. Probably hit the fenders with the boom.
http://members.cisdi.com/~anesthes/p...n/100_5728.JPG
http://members.cisdi.com/~anesthes/p...n/100_5729.JPG
I find it way easier to go in from the side, than straight from the front..
-- Joe
Car: 87 GTA
Re: metal ramps
The 3rd gen nose is so long, that most hoists cannot reach the engine good to lift them out. They tend to run into the nose, before they are far enough in. I've always pulled the nose off, to get the hoist close enough. I've never tried it from the side.
It is also very hard to get the engine & tranny out together through the top. Much easier to separate them, pull the tranny out the bottom & pull the engine out the top.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: metal ramps
That brings up a good point.
I know on all those hot tv car shows they install and yank 'em with tranny attached, but they also have a team of 8 guys helping, holding, watching, etc. I'm usually by myself.
-- Joe
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: metal ramps
Thanks for all the ideas. This is my 1st, 3rd gen car and have never pulled an engine out of one of these. But I have always pulled them together when I was replacing both.Which I will replace both, seems like I read here that it was needed to raise the front high to achieve my goal. I,m sure everyone has their own way of pulling a motor and trans. Sounds like some good ideas to think about before I get to far.
MrPackstin
Oct 25, 2017 08:09 PM
bigjay89gta
Oct 15, 2015 08:04 AM
sjorgens
Oct 1, 2015 07:54 PM
