Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
t-bar conversion
Old Aug 2, 2010 | 09:31 PM
marawder's Avatar
t-bar conversion
Hey everyone. I recently had a 1985 Firebird passed down to me. I also have the windows from my dad's 83 Firebird. From my reading, it seems that the 85 went from latches to pins? Does that mean I won't be able to use my 83 windows? Any help is greatly appreciated.
Old Aug 4, 2010 | 09:25 PM
marawder's Avatar
Re: t-bar conversion
anyone?
Old Aug 4, 2010 | 11:22 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
I'm not sure exactly what you're asking... are you wondering about the T-top latching system? If so, you can use the older style latch strikers (slightly modified with a rat-tail file) to attach the newer style T-tops with pins, but I'm pretty sure you won't be able to go the other way - older T-tops with newer latch strikers - if that's what you're asking about.
Old Aug 5, 2010 | 07:26 PM
marawder's Avatar
Thanks........so I I noticed on the 4th Gen Firebirds there are actually line indents so u know where to cut on the roof......where can I get the proper measurements for my 85? Am I correct in assuming that if I take my headliner off I will see the precut factory T-Bar cut outs?
Old Aug 5, 2010 | 08:02 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
It sounds like you're trying to convert a hard top to a T-Top? I've heard of people cutting out and swapping the entire top. It might be more difficult to cut it out and finish it in such a way that they won't leak especially if you haven't done any fabrication work before.
The mounts for the Tops are interchangeable. You could simply get a hold of some latch type mounts but they're not as common. Don't know if a hard top is going to have a place to attach them either.
Old Aug 5, 2010 | 08:10 PM
83 Crossfire TA's Avatar
My '87 TA has the same pins that my '83 had... The t-tops are a little different but they're interchangeable.
Old Aug 5, 2010 | 08:33 PM
marawder's Avatar
Ok, I am a little confused.....it was my understand that if you cut the top roof pan off......thats the factory Tbar cuts are underneath?
Old Aug 5, 2010 | 08:59 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
wow you really need to describe what you are wanting to do are you putting older tops in a newer car or are you converting your hard top to a t-top car ...there are alot more parts involved to that than just the tops ...and if you youll find that many people have converted hard tops to t-tops and the best way is to have a doner car to cut the entire roof off of and replace yours with it ...a t-top cars roof is two inches shorter than a hard tops roof
Old Aug 5, 2010 | 09:07 PM
marawder's Avatar
wow, thats good to know. Yes, I want to convert a hard top to T-Tops. I watched a conversion done on You-Tube with a 4th Gen. It looked so easy......but I guess its different with a 3rd Gen.
Old Aug 5, 2010 | 09:20 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Its not the same as a 4th gen. Here is the best thread I found about how to do it properly. Its not for the light hearted.
https://www.thirdgen.org/forums/body...-top-roof.html
Old Aug 8, 2010 | 09:52 PM
marawder's Avatar
thanx for the info everyone.............
Old Aug 9, 2010 | 04:01 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
let us know what you decide and you should do a build thread if you swap roofs!
Old Aug 9, 2010 | 05:05 PM
marawder's Avatar
Does anyone know what I will see if i pull the headliner off? Is it just flat roof or??????????? Think of either a big sunroof or even a moon roof???????????
Old Aug 10, 2010 | 04:32 PM
AmorgetRS's Avatar
It's not a flat roof, there is a bar running down the center.
Old Aug 11, 2010 | 06:53 AM
marawder's Avatar
Is the bar there for the factory t-bar cut outs? Also, if I added a sunroof will the bar be a major issue? Will it compromise body stability?
Old Aug 11, 2010 | 04:16 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
the bottom half of the bar looks similar but they are not the same. you would need to cut both your A and B pillars to swap roofs. that is the only way to do that task correctly. I have seen some that had a sunroof but they cut out the center bar and the flex causes many leaks. If you cut that bar out you need to replace it with a couple of bars on either side of the sun roof. Just remember that GM didnt spend millions of $ just to put some unnecessary piece on the car, The engineers put that bar there for a purpose.
Old Aug 11, 2010 | 04:22 PM
AmorgetRS's Avatar
Adding the sunroof was somewhat common back in the day and I never heard of them ripping in two. Would I do it? No.
Old Aug 12, 2010 | 10:00 AM
el_muerte's Avatar
Car: '87 Z-28
That explains why I keep hitting my head in my buddy's T-top car and why I had to lower my seat mounting points... thought I was imagining it lol
Old Aug 12, 2010 | 12:27 PM
AmorgetRS's Avatar
You are imaging things... the hard top and t-top cars have the exact same overall height.
Old Aug 12, 2010 | 12:33 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
the exact dimensions have been posted here on this site multiple times
Old Aug 12, 2010 | 12:53 PM
AmorgetRS's Avatar
We must be talking about something different, but if the roof height is different then how do the side windows, rear hatch, interior plastics, etc interchange.
Are you taking seat height to ceiling?
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
