Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
camaro spoiler to firebird?
Old Dec 5, 2010 | 11:13 PM
thegoochking's Avatar
how hard would it be to modify the ducktail style spoiler the camaros have to fit the firebirds, i want one on my gta
Old Dec 5, 2010 | 11:20 PM
Stephen's Avatar
Car: 87 GTA
Re: camaro spoiler to firebird?
You would have to drill new holes. Weld old ones shut. And do a repaint back there.
Not hard. Just a matter of if you can do/afford to pay for all that.
No different than my 4th gen wing swap. Drill/Weld/Paint.
Old Dec 5, 2010 | 11:21 PM
wouldnt the spoiler cover any holes since it sits on the trunk itself?
Old Dec 6, 2010 | 12:06 AM
Stephen's Avatar
Car: 87 GTA
I don't know how close the spacing it between the wing & the spoiler, for the 2 center posts.
Old Dec 6, 2010 | 12:12 AM
you do know im talking about the camaro spoiler right?
Old Dec 6, 2010 | 09:59 AM
Pocket's Avatar
Car: 91 Trans Am
Bird wing holes are all over the decklid, You'd for sure have to weld several shut. Easier would be to use a camaro decklid. Be aware the camaro spoiler follows the angled corner tail lights which the bird wont have. It should still fit, just look funny
Old Dec 6, 2010 | 04:28 PM
AmorgetRS's Avatar
Firebirds are wider in that section, so I don't think you could just bolt the Camaro 3 piece on....
Old Dec 6, 2010 | 05:42 PM
Stephen's Avatar
Car: 87 GTA
I think I read it as you wanted the Z28 "F40" wing piece.
To do the IROC/RS style spoiler, you could do it. Easiest way would be to swap whole hatches, then drill new holes in the quarter panels for the 2 end pieces. You wouldn't HAVE to swap hatches, but that might be easier than welding & repainting. And the different width mentioned above is in the quarter panels, not the hatch, so the hatch would be simple to swap.
Not sure how well the spoiler end pieces with match up with the spoiler center on the hatch though. Might be a small gap between the end pieces & center piece, because of the quarter panels being wider, but I'm not positive where the wider section is. If it is in the rear, the whole panel, or just the center or flares.
As for 'bird holes "all over the decklid"? There is just 5 holes (4 bolt holes, 1 wire hole). To do the 4th gen wing, it only took welding those shut & drilling 3 new holes. But the wing does use these clips to hold the forward arms to the glass edge, so you'd still have those. But they can be ground off (they are spot welded from the factory) then the trim touched back up black. So swapping for a Camaro hatch is the easiest way to go.
And as far as the Camaro spoiler following the Camaro lights....True, but it would just end up looking like an early 2nd gen Camaro. Same style spoiler, no tail lights wrapping around on the sides.
Old Dec 6, 2010 | 05:44 PM
AmorgetRS's Avatar
That part of the body is with out a doubt wider. Have you seen the way a Firebird base model spoiler overhangs on a Camaro?
Old Dec 7, 2010 | 11:21 PM
I love that spoiler style on that green z28 i want one like that on my bird. I think it would look so dam sweet.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
I'llrocya
Feb 2, 2016 11:43 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
