mandrel tube bender
mandrel tube bender
Anyone ever researched or have a mandrel tube bender that allows for a 1" radious bend on 2" or smaller tube but can also work with max 6" OD tubing? I want something that I can use to make small intricate bends for turbo headers but also big enough to make full exhaust for a diesle and chassis fabrication.
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Re: mandrel tube bender
A 1" radius bend on a 2" diameter tube doesn't leave a lot of room for the bender.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
A mandrel bender that can do 6" tubing you say? Sure, a company in my town makes a bender that can do that.
http://www.bii1.com/benders/mandrel/...el-benders.php
Not sure on pricing, but I can guarantee you its well north of 50 grand. Probably closer to 100.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
From the link...
So.. Yup.
Originally Posted by From The Link
With our most powerful boosters some of these models can be fitted to bend as tight as an incredible 1/2 X OD. Now that is an extremely tight bend!
Car: 1990 formula
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For things like turbo headers, it's probably easier to just buy mandrel bent J or U tubes and cut and weld to the exact shape you want.
The cost of a tubing bender is cheap. The cost of a good selection of dies gets expensive.
Yes that is why you have a big die selection. Its not un-common to have 10, 15, 20 or more dies to choose from. Not only do you need a die for each ID bend but round and square tubing as well. That's when if you know someone with a lathe, they could make you a set of a coupple custom dies.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
hit ebay, you can find plans for all sort of things like that to build.
I got a set of plans for a bender like that, but like said, its the dies that add up quick.
I can tell ya you can use one of those HF pipe benders you can get for $100 with a bunch of dies, the trick to them is fixing the dies, you must weld on more material and shape so they fit snug to the tubing your using up the sides. And then it will make nice smooth bends and not kink. Know a guy who uses one to build motor cycle frames.
Car: 1990 formula
Baighleigh makes some super nice stuff. Check out their vise clamp type tubing notcher. I want one!
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
