Roll Cage Install Help
Car: 84 camaro berlinetta
Engine: 383 stroker Bored .40 over
Transmission: th-400 hughes 2500 Stall
Axle/Gears: moser axles 3.73 gears
Whats Up Guys, I Have An 84 Berlinetta Im Installing THe Jegster 8 Point Cage And I Was Wondering If Anyone Could Help By Putting Up Pics Of The 8 Points On The Car You Welded To. I Am Running Into The Bump On The Floor Where The Hoop Mounts And Was Wondering If There Was Any Tips Or Tricks I Would Need To Know. Thanks!
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Roll Cage Install Help
Bump on the floor are you talking about the back seats or the passenger side front? Passenger side front I just bent the plate to wrap the contour of the floor. Rear seats I removed and put my mainhoop there. I'm 6'4 so I need all the leg room I can get. Use the plates included. Most kits come half way cut. You will probably have to trim and adjust it some. I used the S&W kit with dual swing outs. You need to have it at least MIG'd (gas shielded) if you want it up to tech specs. Don't think you can do it with a stick welder or something. If you're going by tech specs they have measurements for where the mainhoop and etc should be placed (so far over driver's helment etc).
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
fireturd350- Stupid question.. hows the rear visability with the "x" brace in the back for the rear bars??
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The X-brace should never be high enough to cause visibility problems. The only mirror I use is one I have mounted inside the car. I don't even see the rear tubes. Looking at his picture, I don't really like how the rear tubes are run.
As for mounting the main hoop on the hump. Weld the 6x6 plates onto the hump then heat them up with a torch to fold them over the sides. All your tubes should be welded to 6x6 plates.
Engine: 383 SBC
You can see them in the mirror, but not a big deal. Only reason why I did the x-brace was I had extra straight weld in door bars left over.
ambainb
Apr 25, 2016 09:21 PM
