Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
HIDDEN - Over flow and washer tanks - Built on the cheap!
Old Mar 7, 2013 | 04:22 AM
  #51
bignastyIROC-Z's Avatar
Car: 1988 iroc-z
Engine: building a 360 now almost done
Transmission: 700r4 w ratchet shifter
Re: HIDDEN - Over flow and washer tanks - Built on the cheap!
making and hooking up the tanks
Old Mar 7, 2013 | 11:03 AM
  #52
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I could make you a set...
Old Mar 8, 2013 | 08:41 AM
  #53
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
What about venting for the coolant?
Old Mar 8, 2013 | 11:23 AM
  #54
FueledSoul's Avatar
overflow on your left, washer on your right (both upside down) see the two 90* fittings? the top one is the *vent* and if it gets to full which it won't, it can purge...
Old May 16, 2013 | 12:59 AM
  #55
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I saw this post long ago and loved the idea but never tried, found it again and I think its time to give it a shot, have you tried or thought of a clear fluid level viewer possibly? That's one thing I might try to add if I attempt this. Just something to keep an eye on the levels without unscrewing either tank.
Old Jul 4, 2014 | 04:31 PM
  #56
ciar623's Avatar
Car: 1986 Z28
Engine: 355
Axle/Gears: open 2.73's
How did you thread the PVC pipe? Is that something that Home Depot or Lowes could help me out with? I am just a little concerned about the temp of the coolant. My Z28 runs a little hotter than normal.
Old Jul 4, 2014 | 05:17 PM
  #57
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: HIDDEN Over flow and washer fluid tanks - Built on the cheap!
Originally Posted by FueledSoul
Iv been procrastinating on fabricating a set tanks... so i decided to try and make some out of PVC...
Materials
Glad to see you are using my companies pipe!!
Old Jul 9, 2014 | 10:58 AM
  #58
WTR388's Avatar
Car: 87 Trans Am
Check out the post below yours, you can see there is a fitting that is a female threaded portion and then there is a male threaded cap.
You would have to glue the female fitting on to your pipe.
Just go on in and walk the aisles of lowes/HD or whatever you have.
Old Jul 10, 2014 | 10:20 PM
  #59
FueledSoul's Avatar
I drilled and tapped them...
Old Jul 10, 2014 | 10:38 PM
  #60
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I think he meant for the pvc caps.
That looks awesome man. Great idea! Think I just found my new washer bottle, lol. Old one is cracked top and bottom and there is no room for it anymore anyway.
Old Jul 11, 2014 | 02:11 PM
  #61
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I plan to do this. How have they held up over the past 3 years?
Old Jul 13, 2014 | 11:09 PM
  #62
FueledSoul's Avatar
Just fine
Old Oct 1, 2014 | 04:49 PM
  #63
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Would look great chromed witha cap that extends thru the filler panel.
Old Feb 15, 2015 | 06:45 AM
  #64
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
Can you explain to me what the 2 brass fitting are for on the one tube?
Old Feb 20, 2015 | 05:01 PM
  #65
FueledSoul's Avatar
Old Mar 29, 2016 | 09:20 PM
  #66
haro_is_king's Avatar
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
props to the op for the great idea, as i also hated my dirty huge tanks. i made mine out of 3 inch pvc and are about 11 inches long. i took the filler panel out to allow the tubes to be mounted vertical as i thought it would be optimal. i will be using some metal roll strapping that has holes in it and going around the tubes then putting a screw through a hole in the strapping into the frame. thanks again for the idea.
coolant left/ washer right
Old Mar 29, 2016 | 09:26 PM
  #67
finished painting and starting to glue the ends
doing a leak test after drilling and tapping holes, i did use plumbers tape
Old Mar 29, 2016 | 09:35 PM
  #68
coolant bottle
washer bottle
Old Jun 11, 2016 | 06:54 PM
  #69
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Great mod. Will be doing this soon. Do you have a parts list ? And how long did you make the pvc tubes ?
Old Jul 3, 2018 | 07:16 PM
  #70
Go Blue's Avatar
Sorry to bring back an old thread, but I really like the design! Great work! Other than the tapping the pvc did you use glue or anything to attach and seal those brass fittings? And what size fittings did you use for this project?
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
snowflake
Oct 19, 2015 10:24 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
fonzie85
Aug 13, 2015 11:50 AM
