Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Stock Style Fuel Cells?
Old Dec 11, 2011 | 03:59 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Does anyone know if they make a fuel cell to fit the stock location. I have had no luck finding anything, thanks.
Old Dec 11, 2011 | 04:28 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
Re: Stock Style Fuel Cells?
FuelSafe has one but its retardedly over-priced (to the tune of $3k)
I am working with Ricks hotrod tanks to get one for my 3rd gen.
Old Dec 11, 2011 | 04:31 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Yeah thats high for a fuel cell let me know how your deal works out with Ricks
Old Dec 11, 2011 | 04:36 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Yes and no. Looking at it, its definitely not your typical fuel cell. Also, its 11 gal bigger than the stock tank:
http://www.fuelsafe.com/store/sa114.html
A bit overkill, but I think it looks reasonably priced all things considered. How much would it cost anyone of use to fab up that kind of fuel cell to begin with? We'd save on labor, but I'd be willing to bet the bladder & foam are the costly part of this operation.
Old Dec 11, 2011 | 04:46 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
I dont like the foam if you run the tank to long it breaks down and gets in the whole fuel system I always take it out so i would rather have one without it
Old Dec 11, 2011 | 05:17 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Hmm. I'll have to keep that in mind. What's your experience with bladders?
Old Dec 11, 2011 | 06:46 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
I dont really know anyone that has ran the bladders before.But the foam is ok if you have it changed every year but i wouldn't take that chance, I have had a few friends mess up their regulators, lines, and even the carb had to be cleaned because of it.
Old Dec 12, 2011 | 09:25 AM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
You can run a 4th gen tank in a 3rd gen right? I've seen some aluminum fabricated cells which mount in the stock 4th gen location.
Old Dec 12, 2011 | 11:27 AM
RoadHammer's Avatar
Axle/Gears: stock
If you need a tank with a bladder and foam, then its a good choice.
That cell is 8 gal. more than stock. Stock is 16 gal.
Old Dec 12, 2011 | 06:21 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Math error on my part Maybe there's one or two types of tanks. With my tank bone dry, burping, and filling it till its flowing over, I can get only 15.5 gallon into the tank.
Old Dec 15, 2011 | 10:56 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I would think that a $1,000 21 gallon fuel tank (or cell) would be something a lot of folks would be interested in... $3K is beyond rediculous!!!
Old Dec 15, 2011 | 02:30 PM
83RDRACR's Avatar
If your not running any exhaust behind the rear axle RCI makes a 15 gallon cell that will mount between the well in the trunk and the panhard bar. Go to Summit web site and check out RCI-2161A. Its 30L X 9W x 12H, has a top filler inlet, top outlet, return and vent fiitings and a GM fuel level sender. I'll be using this in my 83Z track day car.
Yes it comes with the foam inside but speaking from first hand experience the foam last 2 to 3 years. It is wise to take new foam blocks and rinse them in soapy water and then blow dry with compressed air as they have a lot of loose particles in them when new. We race a short track stock car and have never had a bit of trouble with the foam.
Old Dec 15, 2011 | 02:37 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
That's because they are only 15.5 gallons.
Old Dec 15, 2011 | 04:33 PM
wanarun's Avatar
Car: 86 camaro sport coupe
Engine: 350 ci. alluminum headed sbc
Transmission: TH350 w/9" 3800 conv.
Axle/Gears: 31 spline strange /4.11
Why do you want to use a fuel cell? If you want your fuel lines to come out of the bottom instead of the top, You can weld a bung in the bottom of the tank. It already has somwhat of a sump design. I have done it and had no problems with it.
Old Dec 17, 2011 | 06:59 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Axle/Gears: moser 9" with 411 posi
i have a tank/cell that fits in the factory location. you just have to use a 4th gen filler neck which i have. you would also have to run a vent line. it even has a sending unit that will work with the factory gauge. im selling it for $450 plus shipping. it was over $800 new. let me know if your interested. here are some pics
http://s54.photobucket.com/albums/g1...cpZZ2QQtppZZ16
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
