Fuel tank for external pump
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
Hey Everyone
I am installing an aeromotive a1000 fuel pump in my 89 camaro and was wondering if it would be alright to simply weld a bung in the bottom of the tank for the feed line. I don't plan on doing any wheel stands soon so I'm not too worried about cavitating the pump if you guys think it would be alright.
Steve
Steve
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Fuel tank for external pump
i did that just make sure it at the farthest point back on the tank wall so the fuel rushes to it and you'll be fine and just leave a 1/4 tank or so of fuel
Engine: 4++,350 & 305 CIs
It looks like a mockup pic buuut if those are Baer rotors that one is on the wrong side.. (im sure you know)
mockup yes but the rotors are on correctly. If you drive forward like you do in most cases
the vanes are curved backwards, they are directional vanes. As the curve rotates the air inside is accelerated and the rotor acts like an air pump... directional vanes always cure back
same rotors, different pic
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I think he was referring to the slot direction, which according to Baer and SSBC at least, would be incorrect on your setup. The rotor pictured above would go on the right side of the car if it were a Baer.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That rotor with the Corvette caliper on it is a left side. Air goes out the edge of the rotor, not in.
Humm eat crow... they are on incorrectly. The vanes appear to not go the same pattern as the drilled holes. i had marked them beforehand (HL = rear left, HR = rear right, VL = front left and VR = front right) and I used them for mockup only but dang..I would have thought they were drilled along with the vane, not directly against it.
You can just see the vanves curve the other side in this pic. I would have checked it on final assembly but I didn't notive the drilling rotation before.. how weird
I used to sell/b a dealer for Baer, plus I have 3 cars with Baer rotors on em..
For normal driving it will mostlikely be just fine buut if your plaining some hard driving better get them installed on the correct side.
I looked on Baers site for the install directions and its not on there yet. I better tell them to get it up there....
I would not have installed them incorrectly, I would have double checked the vanes and my markings on them
they are for mockup only now and the fronts I probably won't even use.
they are for mockup only now and the fronts I probably won't even use. Thread
beachrodder
Aug 25, 2015 08:05 AM
