Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
t5 install
Old Jul 1, 2012 | 09:48 PM
highgear's Avatar
Car: 1988 IROC-Z
t5 install
I have an 88 iroc. Was an auto and is becoming a manual. I got the manual pedals in. Then I sorta guessed where the rod should come through the firewall for the clutch. Grabbed a hole saw and drilled through below the brake booster and slightly to the right. The rod comes through and connects to the clutch pedal but when I push the pedal the rod sorta clicks, or pops. The pedal feels smooth though. I'm just wonderin if this is going to pose a problem or if it should be fine?
Old Jul 2, 2012 | 10:51 PM
toomany's Avatar
Re: t5 install
The firewall should have been dimpled from the factory for the master cylinder spot. The popping might be the push rod moving around on the stud. It could cause premature wear. Problems like this usually don't get better with time/use.
Old Jul 3, 2012 | 04:18 AM
highgear's Avatar
Car: 1988 IROC-Z
Re: t5 install
Yeah I though the spot would be obvious but I didn't see it. Doesn't help the firewall is a little beat up. I guess I'm kinda screwed now. Not sure how I'd get the rod into the right position without destroying the fire wall.
Old Jul 3, 2012 | 08:18 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: t5 install
There are no marks on the firewall. But the pedal are supposed to have support braces that extend down to the firewall and will locate the 2 mounting holes for the master. Is the pushrod in line with the pedals? Or is it at an angle side to side? Are the bushings in the loop of the pushrod present?
Old Jul 3, 2012 | 10:18 AM
highgear's Avatar
Car: 1988 IROC-Z
Re: t5 install
I don't think I have the braces. I got 4 bolts that are part of the brake booster. Then 1 bolt that goues straight up. Side to side it looks fine. I think the push rod is a bit to high. I don't see any bushing. Also I want to add there's no fluid in the system yet. When you push the clutch with your foot its smooth. But if you get down and push it with hand there's a pop that comes from the shaft within the 1st 1/4 inch. Then its smooth.
Old Jul 3, 2012 | 11:54 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: t5 install
you may need the braces as you may be hearing the firewall itself pop since it is only sheet metal.
Old Jul 3, 2012 | 12:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: t5 install
Yeah, without the braces that are part of the pedals and must have been cut off, you will eventually have issues tearing the sheetmetal of the firewall.
Old Jul 3, 2012 | 12:49 PM
highgear's Avatar
Car: 1988 IROC-Z
Re: t5 install
It don't look like pedals have been cut. I guess I'm just confused on what brace is.
Old Jul 3, 2012 | 01:22 PM
LilSki's Avatar
Car: 85 Trans Am
Re: t5 install
If you came from an auto you wont have them unless they came with clutch pedal setup. They are two braces that go around the pedal pivot bolt on each end of the pedal bracket. They then go down to the two studs on the clutch master where the clutch nuts hold everything in place.
Old Jul 3, 2012 | 01:55 PM
highgear's Avatar
Car: 1988 IROC-Z
Re: t5 install
Ok that helps a lot. So I guess now I either find a brace and remount the master or take my chances as is. More welding to patch the hole I made too. Oh well.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
