Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Ground effects issues
Old Jul 6, 2012 | 10:14 AM
High~Cruzin's Avatar
Car: 89 firebird(going full TA custom)
Engine: sbc 383...LSX swap...in wrks
Transmission: 4L80E
Axle/Gears: 94 ws6 rear, 3:42 gears
What's going on gentlemen...first off, i suppose you can say i'm a newbe to the forum. However, i have been a fly on the the wall using a lot of info found on this forum to resolve problems as well as come up up with new ideas...so thanks to all who share ideas...now, my project is a 89 formula firebird. Originaly with 305 tbi, no ground efx, you know the basics. I will be posting tons of pic to share my project and open doors to comments as soon as the forum allows me to...anyways, one issue that im facing right now is putting sideskirts and rear quarter peices on my car...ground effects off 85 or newer gta. I have no mounting holes or metal strip running length of doorway...input?
Old Jul 6, 2012 | 11:03 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: Ground effects issues
first off welcome.
im in the same boat as you. drill the rears really carefuly and for the side you can cut/drill on off another car or make your own like i will be doing in a few weeks.
good luck
Old Jul 6, 2012 | 12:03 PM
Transmission: 4L80E
That kinda confirms what im realizing then...was looking to fab on mounting brackects to install side rails...just didn't know if another route was avalible. How about the metal brackets in the middle?(pillar area). I didn't pull those from the donor, seemed like alot to go through inside car to get them off...
can i do without?Mabey just use urathane body adhessive after bolting everthing else up? Dunno
Old Jul 6, 2012 | 01:59 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Not to sure about what bracket your talking about. i have a Camaro so i know somethings are a little diff but mostly the same.
do you mean the the strip that goes through the middle of the door?
if you have a pic, i might have an answer
Old Jul 7, 2012 | 05:26 PM
Transmission: 4L80E
Srry, been away for awile...once i figure out how to load my pics, you'll deff see wht i'm dealing with should have them up before nights end...
Old Jul 7, 2012 | 05:51 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Jul 7, 2012 | 07:53 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
keep us posted
Old Jul 13, 2012 | 06:16 PM
Transmission: 4L80E
https://www.facebook.com/media/set/?...type=3&theater
need metal strip down door sill to mount sideskirt bracket...dnt know if imma try and fab or take to shop...also showing bottom of pillar area where i dnt have strip to mount(didnt pull frm donor, plus need to drill holes here as well. Also, anyone looking to check out my full project...got pics up. Open to input. Thanks!!!
Old Jul 17, 2012 | 05:45 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
tried looking at it... but al i get is content unavailable.
Old Jul 30, 2012 | 05:41 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
For the T/A style ground effects you need the ground effects and the sill mounting angles. The ground effects bolt on using a metal strip with one or two studs in it for the top edges of the rocker ground effects. The rear quarter ground effects use the same strip with three studs in it. The actual door effects are a straight bolt on using studs threaded into the fiberglass. The front fender ground effects are held on in the fender and underneath and at the top edge by another metal strip with several studs in it. The 85-90 has the ground effects integrated into the front and rear bumpers.
This is assuming you are using 85-90 style ground effects. 91 -92 is different for the door and front fender and with different mounting hole locations for the rear quarters. This is first hand info as I am swapping from broken 91 ground effects to 85-90 style.
I could not see your pictures either.
Old Aug 8, 2012 | 11:08 AM
JSUPreston's Avatar
I was at the local Pull-a-Part over the weekend cherry picking an '89 Pro-Am. Got a few pieces for my '86 T/A. Was hoping to get the gfx, but half were already gone. However, I learned that the rocker gfx on the Pro-Am's apparently do not have the metal braces on the rocker panels. Just a little FYI.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
