Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how do you take apart a tail light?
Old Dec 3, 2012 | 10:32 AM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
sorry if im in the wrong category, but im looking for someone to describe to me how to take the lense off a camaro tail light, grid and rs style tail lights.
Old Dec 3, 2012 | 08:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: how do you take apart a tail light?
The lenses don't really come off. The light is one big assembly. In behind the carpeting at the rear is about 7 plastic wing nuts. Unscrew all of these and the whole taillight assembly falls out.
Old Dec 3, 2012 | 08:25 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Heat it in the oven for a little while around 200*, carefully use a screwdriver to release the little locking tabs that keep the lens stuck to the housing, before you heat them you'll want to remove all of the screws that you can find.
Old Dec 3, 2012 | 09:22 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I recently bought some new old stock GM lenses. You do in fact separate the lense from the body, but you've got to go very slow and the black gunk that seals the two halves might be dried up and like cement.
-- Joe
Old Dec 4, 2012 | 10:02 AM
mac86's Avatar
Engine: Carbed 355
k i did it, now i have to remove the black gunk to reseal it. im gonna be tinting them from the inside, and turning the turn signal amber to red
Old Dec 4, 2012 | 05:33 PM
mac86's Avatar
Engine: Carbed 355
QUestion:
can i tint a tail light from the inside?
Old Dec 4, 2012 | 05:42 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
you will need to tint the outside you wont see it if you do the inside I do a lot of them with candy black then clear coat they look nice
Old Dec 4, 2012 | 05:44 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Originally Posted by mac86
QUestion:
I wouldnt try to, main reasons i'd take one apart would be to swap the entire lens, or to redo the inside reflective paint.
Old Dec 4, 2012 | 07:36 PM
mac86's Avatar
Engine: Carbed 355
ok does anyone know if i can tint the amber section red from the inside or does it have to be from the outside
Old Dec 5, 2012 | 09:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
If you really want it to turn out well:
Get another set of lights to take the red section out of, cut out the amber section from the set you are building, and install the red section with epoxy, then filler/sand them until perfect, tape off the colors and repaint the lines black.
Old Dec 7, 2012 | 12:59 PM
fyrebird68's Avatar
Can you deal with a delamination problem by taking the lights apart?
Old Dec 7, 2012 | 01:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Not really, thats within the layers of plastic, have to replace the entire lens itself.
Old Dec 13, 2012 | 05:24 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
All you need is VHT red semi translucent paint, I did the same for my tail lights when doing the sequential tail lights. Just do around 3 coats of red and I did 2 coats of VHT Nightshades after that, all on the outside. If you use stock incandescent bulbs it looks like a really deep orange but with new red LEDs it looks great.
Old Aug 8, 2021 | 09:45 PM
Josh Peel's Avatar
I know this message is old but where did you buy the old stock lens? Tu
-- Joe
Old Aug 10, 2021 | 08:01 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I would love to know that to!
I tinted mine years ago from the inside with translucent red paint.
3 coats inside and 3 coats outside.
I didn't do a great job and now want to go back to stock. Think it makes more sense to buy a new set. I used some super strong caulk to seal them up again. Ugh... No way I can get these open again.
I also contacted KLEAR who made lenses for these cars in clear and tint, red, etc... They said they are getting ready to do a run "soon".
I am on the email waiting list. I also don't need them for at least a couple years, so fine with me. Might not be fine for others.
Classic Industries also shows that they have new inner, outer and full assemblies listed, but they all say "coming soon". I haven't called to ask when soon is. Again, don't care for a couple years.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
