Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
new camaro console gauges
Old Dec 16, 2012 | 03:08 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Has anyone had the idea to try and incorporate the new Camaros console gauges into a third gen camaro? If so any ideas on how to make it work?
Old Dec 16, 2012 | 04:59 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: new camaro console gauges
it would probably be easier to integrate the 67-69 Camaro console gauges that they styled the new Camaro gauges after, since they were standalone gauges that would be easy to install and i'm pretty sure the gauges in the new Camaro are controlled by the ecm.
but i don't think there's really a good place to put them where they wouldn't look totally out of place in a third gen, and they did a pretty good job of including every gauge you'd probably need into the stock 3rd gen gauge clusters.
Old Dec 16, 2012 | 12:14 PM
abray1's Avatar
I have the 68-69 console gauges and they are really to big. The newer console gauges are smaller and slightly stacked and have the oil and trans temp gauge which our cars don't have. I figure a custom figerglass piece would have to be made from about the top of "Park" on the shifter forward. The gauges would have to have a new custom cover that would stack them more kinda like a late 60s impala.
Old Dec 17, 2012 | 11:35 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Do you really want to have to look over and down to see your gauges??
Personally I have never been a fan of vital info not being in front of my face........
Just an opinion...........
Old Dec 18, 2012 | 03:10 AM
abray1's Avatar
Well vital is different for each gauge at different times. The tach is not important untill you are reaching 7500RPM and needing to know exactly when to shift vs at a red light going to the store and shifting through the gears below 3000RPM. Or, the temp gauge in the middle of August in town in traffic vs February on the interstate. The trans and oil temp gauges would be perfect down there along with a vacuum gauge etc.
Old Dec 30, 2012 | 05:46 AM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
That gauge placement has to be one of the dumbest things GM has ever done....I test drove a new SS ...At the park & shine car show this past summer...nice car ...It had a heads up display..and the stupid gauges under the dash in the center.....just my 2cents ...
Old Dec 30, 2012 | 12:56 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
I personally like the placement of the gauges on the 1st gen and the 5th gen in the console but not sure how it would look or work in a 3rd gen. I doubt you will be able to use the factory 5th gen gauges because as mentioned above they recieve all their signals from the vehicles ecu. I think autometer sells aftermarket pieces for the 1st gen setup.
Old Jan 21, 2013 | 11:37 PM
mjpcamaro's Avatar
Car: 1969 camaro
Engine: 1992 TPI350
I have a 1969 camaro with the tpi350 in it from a 1992 camaro. I have recently installed the 2012 console because I think it looks much better than the original 69 console. I have been trying to figure out how to get the gauges working. So far it looks to be challenging as others have already mentioned the gauges are controlled by the ECM. Half of the gauges were not originally equipped wich means no sending units. We will have to either use our computer signal and convert it from obdi to obdii or bypass all of the electronics in the gauge pod and directly wire the sending units to the gauges with the proper sized resistors wired in to drop the remaining load. Has anyone else tried anything similar?
Old Jan 22, 2013 | 04:08 AM
novaderrik's Avatar
Car: 86 Camaro
they probably have stepper motors in the new gauges, so just running a wire to the sending unit won't do anything..
1992 Trans Am
May 10, 2023 07:19 PM
rocn7roc
Sep 21, 2021 02:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
TheJoeY88
Aug 13, 2015 06:51 PM
