Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How to make a true cai
Old Aug 9, 2013 | 10:19 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
I need help on a simple but effective way on how to stop sucking in the motor temperatures. I tagged a pic I'm open to any ideas but I don't wanna cut into the car. Thanks
Old Aug 9, 2013 | 10:34 PM
Joe Tag's Avatar
Re: How to make a true cai
The tpi intake draws air from outside the engine bay in front of the a/c condenser. (goes in place of the plastic cover around hood latch) I guess you could argue it will be warmer air because of its proximity to radiator, but I'm not buying it.
Old Aug 9, 2013 | 11:09 PM
jaybdaboat's Avatar
I have the lt1 some reason the pics never load
Old Aug 10, 2013 | 02:48 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
get a TPI intake setup... it hooks up to an LT1 like it's meant to be there, and draws cool air thru a pair of filters in front of the radiator...
a setup off a V6 will also work- i'm pretty sure it's the same parts as the V8 TPI cars.
Old Aug 10, 2013 | 09:33 AM
jaybdaboat's Avatar
I thought that intake was restrictive after so much hp
Old Aug 10, 2013 | 10:10 AM
novaderrik's Avatar
Car: 86 Camaro
every intake is restrictive after a certain point... a mostly stock LT1 is not at that point.
Old Aug 10, 2013 | 12:54 PM
jaybdaboat's Avatar
Next year I plan on adding a cam and stall. This year gears and tune.
Really looking for ideas for a intake shield rather than switch my intake
Old Aug 10, 2013 | 01:34 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Build a heat shield, i did: Name:  IMG_7639.jpg
Old Aug 10, 2013 | 01:42 PM
jaybdaboat's Avatar
What materials did you use?
Old Aug 10, 2013 | 01:46 PM
Rich92 RS's Avatar
Transmission: T56's
ABS Plastic
https://www.thirdgen.org/forums/fabr...d-battery.html
Old Aug 11, 2013 | 01:39 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
This is a setup I made for my 2.8L several years ago. It is better than a heat shield as it draws cold air from outside the engine bay. You can't see it in the pic, but I used a 4" hole saw to cut a hole were the evap canister used to be and then routed the tube through it with the cone filter on the other end.
Old Aug 11, 2013 | 08:27 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Step 1. Take your filter off. Step 2. Cut a hole in the battery tray. Step 3. Add more plumbing so that is goes through the hole. Step 4. Attach filter.
You couldn't use the TPI setup anyway, you don't have the plastic for the filters. Not that you would want to use that garbage setup.
Old Aug 12, 2013 | 12:46 AM
jaybdaboat's Avatar
Well where do I get 1 chrome tube?
Old Aug 12, 2013 | 07:23 AM
Dakota W.'s Avatar
Why do you need a chrome tube?
Old Aug 12, 2013 | 07:26 AM
jaybdaboat's Avatar
My intake is a 2 pc chrome. Don't want chrome ,chrome , PVC lol
Old Aug 12, 2013 | 07:51 AM
Rich92 RS's Avatar
Transmission: T56's
Try siliconeintakes.com
If you run the filter under the battery tray keep in mind you can run the risk of sucking up water.
Old Aug 12, 2013 | 10:47 AM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
If you don't want to slice a hole in the car you could always get a ram air hood and make some duct work that will seal to the hood. The air would be plenty cold & clean
Old Aug 28, 2013 | 02:38 PM
jaybdaboat's Avatar
So I think I want to try "ram air." But with a little twist. There is a hole beside the radiator that I can use PVC or a dryer duct of some kind and attach it to a fog light hole. Then try to seal it off the best I can so it only gets that air.
Old Aug 28, 2013 | 04:13 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
That has been done with some good results.
Check out these links for some ideas:
https://www.thirdgen.org/forums/auto...-air-pics.html
https://www.thirdgen.org/forums/tpi/...pi-camaro.html
Old Aug 28, 2013 | 05:57 PM
jaybdaboat's Avatar
Oh I read those. Those are Over the radiator ram air. I removed my ac so I have a gap like I'm sure most do. And I want to force air threw there, where my intake currently sits. Is this a stupid idea so I'm the first?
Old Aug 28, 2013 | 06:32 PM
Rich92 RS's Avatar
Transmission: T56's
Nevermind, didnt understand what u wanted to do
Old Aug 28, 2013 | 08:38 PM
jaybdaboat's Avatar
Something like this
https://www.thirdgen.org/forums/fabr...om-intake.html
Old Aug 30, 2013 | 08:56 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Ah I see. It's not a stupid idea at all. But your either going to have to modify an existing cold air kit from another type of car, or make it all from scratch.
Old Aug 30, 2013 | 10:03 PM
jaybdaboat's Avatar
Well I attempted it. And it works. It's not for show tho lololol.
I got 6" flexible dryer duct attached it to my fog light hole. Grabbed some pliers and made a bigger hole by the radiator. Then I was able to squeeze the duct through. I used a 3 gallon tub with a lid. Cut a hold in the top of lid, and a hole in the side. Added more dryer duct threw the hole of the tub which goes inside the duct from the fog light. I'm going to use weatherstripping for the lid for a good seal. And get a better seal for the duct, then spray paint the lid black for a better look.
But I put my ear by the intake and don't hearing and sucking noises but I can hear a sucking sound from fog light, so I guess it has a good enough seal.
It pulls harder and smoother all the way up to 6000rpm.
Old Sep 2, 2013 | 03:17 AM
RSFreak's Avatar
Mine sat at least 18" above the ground, so the chance of sucking up water was minimal.
Old Sep 2, 2013 | 10:13 AM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
You can get spectre cai parts at Oreillys and advance and probably some other parts stores. Or you can order spectre from jegs or summit. I've wondered if with the spectre stuff if you could make a ram air setup through the high beams with their headlight RA brakets.
Old Sep 2, 2013 | 07:07 PM
jaybdaboat's Avatar
How it looks in my intake
Old Sep 2, 2013 | 07:10 PM
jaybdaboat's Avatar
How it looks threw my fog light.
Old Sep 2, 2013 | 07:24 PM
jaybdaboat's Avatar
Top view. It works not a looker tho
Old Sep 4, 2013 | 12:57 PM
Dakota W.'s Avatar
That spectre stuff at Oreillys and advance is such a ripoff, the quality is CRAP for what you pay. I'd sooner put home depot pcv on my car than that junk.
Old Sep 4, 2013 | 05:26 PM
Car: 92 Camaro RS
Could you elaborate on this? What is spectre's shortcoming/fla? I can imagine their filters but what is low quality about their piping? I don't know anything about them but I've been impressed by their intake kits and variety of accessories to build a custom one.
Old Sep 5, 2013 | 09:23 PM
Dakota W.'s Avatar
The material they use for their parts is just REALLY cheap and doesn't hold up well. I don't even know how many times I had to warranty some of their parts because they broke. The $200 kit is probably okay, but I would advise staying away from their DIY plumbing pieces. The filters seem to hold up well, surprisingly.
Old Oct 11, 2013 | 03:58 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
You know I've been toying with the idea of building a functional CAI out of those "adjustable" 4 inch aluminum dryer vents ( the ones that are able to be twisted and straightened) and a 4 inch straight tube. It should only cost about $20 bucks to build. Thanks for the inspiration
edit. This is what I'm talking about
elbows
http://www.homedepot.com/p/Speedi-Pr...5#.Ule-Y77nbIU
straight tubing
http://www.homedepot.com/p/Deflect-o...6#.Ule-6b7nbIU
then probably cut a hole and have this bolted on to draw the air up to the filter box
http://www.homedepot.com/p/Deflect-o...7#.Ule_k77nbIU
Old Oct 11, 2013 | 08:28 PM
jaybdaboat's Avatar
elbows
straight tubing
I looked at that stuff, it would be pretty difficult to get it in. The 6in ducts works great.
Old Oct 11, 2013 | 09:46 PM
Dakota W.'s Avatar
elbows
straight tubing
....And this is why everyone assumes we all have mu11ets...
okfoz
Mar 9, 2017 02:35 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
formula_novice
Sep 5, 2015 03:58 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
