Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
8.8 ford torque arm fabrication
Old Mar 28, 2014 | 04:50 PM
emkay4865's Avatar
does anyone know of a ready-made torque arm that's made for the 8.8 ford rear end? or, a proven set of plans/illustrations showing how to fabricate the bracketry to the 8.8 rearend?
Old Mar 28, 2014 | 06:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8.8 ford torque arm fabrication
Since an 8.8 swap is only done by owners and not offered as an aftermarket swap diff, there is no commercially available kit to mount a torque arm onto the 8.8. If you want to install an 8.8, you need to use a lot of fabrication skills and create your own mounting attachment. Use the search feature to see 8.8 options on the few who have done the swap.
By the time you're done, it's probably a lot easier, cheaper and safer to just install an aftermarket direct bolt in 9" or 12 bolt under the car.
Old Mar 28, 2014 | 08:29 PM
BOSTONCAMARO's Avatar
we did a 12 bolt...but we scored. on parts and we had means to do it...there was just a direct bolt in 9 inch housing locally...asking price was 500, the guy was tubbing car so the 9 had to go...alky is right, often we try to save money when in the end you dont...ive seen several 9 inches direct bolt ins for third gens on craigs for very reasonable prices like 900 asking price complete, with posi, good gears, axles etc
Old Mar 28, 2014 | 08:46 PM
3GZJerry's Avatar
Car: 1990 IRoc Z
I seen 9's go for that amount but there was something always missing like the center section whic bring the price up. I'm doing a 8.8 swap Nd just picked up the recommended explorer 8.8 with factory limited slip 4.10 gears 31 spline for $100 at the junk yard on my first visit. Saw another with 373 gears there also. I have a guy who will do all the fab work who's done this before. The torque arm bracket is sold for $45 which gets welded on as well. I just need to order new 31 spline axles and I should be done. I will post more info when I get started.
Old Mar 28, 2014 | 09:05 PM
post pics, would like to see it for sure...yeah a 9 inch in boston just sold, was complete, bolt in asking price was 900, but i hear you if you can score parts nothing wrong with fabbing it all up.....we are happy with our 12 bolt...setting up brake lines now
Old Mar 28, 2014 | 11:03 PM
3GZJerry's Avatar
Car: 1990 IRoc Z
would have loved to done a 12 bolt boston but it wasn't in the budget. locally nothing here cheap and once you factor in the shipping it was to expensive to get everywhere else. On top of everything I'm doing a LS swap so i'm already crawling out the money pit so I have to save where I can. thats why I'm on this 8.8 build which I should be more then happy when I'm done.
Old Mar 29, 2014 | 05:34 PM
Granny's Avatar
I make a bolt-on TA for the 8.8, it's not Camaro specific though...
It's part of the package i make to install an 8.8 into an RX-7.
Old Mar 29, 2014 | 05:44 PM
3GZJerry's Avatar
Car: 1990 IRoc Z
How much is this kit?
Old Mar 29, 2014 | 05:51 PM
skinny z's Avatar
Originally Posted by 3GZJerry
The torque arm bracket is sold for $45 ....
Any more information ? Manufacturer? PN?
Old Mar 29, 2014 | 06:00 PM
3GZJerry's Avatar
Car: 1990 IRoc Z
It's sold by a member on ls1tech. Comes in pieces and has to be welded together.
Old Mar 30, 2014 | 06:40 PM
if you dont have the means to fab maybe find a local welding shop? fab shop that does some car work....
Old Aug 1, 2023 | 03:12 PM
Dustin1988's Avatar
Does anyone still make this kit?
Old Aug 1, 2023 | 03:14 PM
Dustin1988's Avatar
Do you still sell this kit?
Old Aug 1, 2023 | 09:49 PM
skinny z's Avatar
Maybe...
https://www.hawksmotorsports.com/82-...-end-assembly/
Old Aug 2, 2023 | 01:49 PM
Dustin1988's Avatar
Thank you sir.
Old Aug 2, 2023 | 04:16 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
These are the brackets you want for your 8.8 then use whatever torque arm you've already got
https://www.ebay.ca/itm/295493555216...mis&media=COPY
Old Sep 6, 2023 | 06:53 AM
Dustin1988's Avatar
Thank you. Just ordered the Brackets.
Old Dec 13, 2023 | 05:27 PM
lt1b4c's Avatar
Car: Iroc 88
Engine: 350 LT1
Axle/Gears: 10 Bolt 4:11
Curious where you stand with this project? What's everyone do with the other brackets that go on the axle tubes?
Old Dec 13, 2023 | 05:28 PM
thatsupnow's Avatar
You can buy new brackets for the rest of the suspension from places like Moser and Midwest Chassis. I'm sure there's other places out there too
Old Dec 13, 2023 | 07:12 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Racecraft makes bracket for the lower control arms too.
https://www.racecraft.com/housing-br...kit-p-706.html
Ive also seen people cut the old brackets off and weld them to the new axle tubes, but that seems kinda sketchy for alignment reasons.
You can also cut the axle tubes right off your old axle and weld them to 8.8 center section.
car469999
Jul 12, 2021 01:30 PM
customblackbird
Jan 3, 2016 04:00 PM
grease
Dec 29, 2011 06:54 PM
ck88camaro
Fabrication
Apr 25, 2010 06:52 PM
SERPENT99
Fabrication
Jun 21, 2004 12:49 AM
