Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cylinder head mounting template
Old Jul 5, 2016 | 02:51 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hello,
Wasn't sure if anyone knew where I could download a printable template of the accessory mounting positions on SBC cylinder heads.
I can make one out of cardboard, but I'd rather have one that was done in CAD or something that's 100% dead on.
-- Joe
Old Jul 9, 2016 | 10:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Cylinder head mounting template
I had a similar issue once so I went out and bought the harbor freight set of transfer punches and then a transfer screw set also. They work great. I thought you engineers all had a magic drawer where you could pull out any precise tool you wanted- just like a magician's hat.
http://www.harborfreight.com/28-piec...-set-3577.html
http://www.ebay.com/itm/7-PIECE-TRAN...QAAOSwo6lWITJC
Old Jul 11, 2016 | 09:46 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks, I'll give that a try.
I'm not a mechanical engineer, no magic tool box.
-- Joe
Old Jul 11, 2016 | 10:16 AM
Twin_Turbo's Avatar
Uhm factory drawing from power manual? Or do you need a complete engine? Grabcat has some
Old Jul 11, 2016 | 11:59 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Grabcad ? I'll check it out. Thanks.
-- Joe
3rdgenkindagal
Apr 13, 2017 01:30 PM
85@IRocZ
Jul 17, 2016 05:28 PM
Dartht33bagger
Jul 8, 2016 01:01 PM
Carlover866
Jul 8, 2016 04:42 AM
shrewdpeach1609
Jun 28, 2016 10:57 AM
