Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Dual exhaust cross member
Old Mar 26, 2018 | 03:21 PM
onebdgti's Avatar
I am running headman long tube headers and was wondering how many people have modified there stock transmission cross member. My car is running a 700r4 and its tight under there for dual exhaust.
Old Mar 27, 2018 | 01:38 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Dual exhaust cross member
I have one for sale.
https://www.thirdgen.org/forums/mid-...ml#post6023197
Old Mar 27, 2018 | 05:36 AM
onebdgti's Avatar
Isnt yours for an ls swap?
Old Mar 27, 2018 | 07:10 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't know all the options for plug and play. The adapter plates for different transmissions are sold separately by Holley. You would have to ask them. Maybe you would have to make your own adapter plate.
Old Mar 27, 2018 | 12:35 PM
onebdgti's Avatar
Thanks but i will fab one up.
Old Mar 27, 2018 | 04:22 PM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
You CAN run it under the cross member, may be too low depending on what size your using.
I switched to a th350 tubular crossmember for my swap, but the original is literally straight into the cross member, so your going to have to cut it, and weld + mount it in the tunnel away from where you need the header.
Old Mar 27, 2018 | 07:50 PM
skinny z's Avatar
I've modified my OEM crossmember for as much ground clearance as possible.
This is with Hedman LT headers. The y-pipe was built using mandrel bent pieces welded together in sections.
Still affords about a beer can's worth of ground clearance although truthfully, I've crunched the y-pipe more than once. This is with a "two inch" drop spring package.
Attached Thumbnails Dual exhaust cross member-100_1844.jpg   Dual exhaust cross member-100_1896.jpg   Dual exhaust cross member-100_1900.jpg   Dual exhaust cross member-100_1948.jpg   Dual exhaust cross member-100_1951.jpg
Old Mar 28, 2018 | 12:58 PM
onebdgti's Avatar
That more ground clearance than going totally under the stock flat cross member. I plan on fabbing up my own exhaust after I install my sub-frame connectors. Wanna make sure what all space I am gonna have.
Old May 21, 2018 | 02:42 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i just bought this
but haven't installed it yet
https://www.holley.com/products/ls_p...ts/71222005HKR
Old May 21, 2018 | 03:02 PM
skinny z's Avatar
I have the same crossmember sitting on the shelf.
I was kind of forced into it as my 700R4 is built around a Corvette transmission case and that puts the rear transmission mount of the extension housing rather the case itself. Now my rear trans mounts puts the installed length within a 1/16th of that of a TH400.
Plenty of room for exhaust with this part and it gets the arm off the trans too.
91ls1t56
Fabrication
22
May 15, 2016 10:22 AM
AkDrifted
Jul 29, 2015 04:45 PM
1991_RS
Jun 27, 2012 01:27 PM
dingle
Jun 29, 2006 11:44 AM
downwithET
Aug 22, 2002 01:42 AM
