Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lit Plates
Old Jun 9, 2018 | 02:26 PM
TireSmokin''s Avatar
Lit Plates
We have applied for a patent for these.
The first two are renderings and the last two are of an actual piece.
The designs are limitless, and we've already done several different designs for people.
Un-lit...
Lit...
These look nice during the daylight when lit, and RGB is available, but won't be offered, or offered as a add-on kit for do -it -yourself, as many states have strict regulation on colored lights on the front of vehicles. White doesn't typically create issues.
Old Jun 11, 2018 | 09:09 AM
Go Blue's Avatar
Re: Lit Plates
Those are cool looking!! Great job! How much are you thinking of asking for them? Would you be providing the wiring for them to hook into the normal wiring somewhere?
Old Jun 13, 2018 | 02:31 PM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
Re: Lit Plates
is it just me or are the pics not showing?
Old Jun 13, 2018 | 03:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Lit Plates
Just you.
Old Jun 14, 2018 | 04:14 PM
Re: Lit Plates
These don't have to be plates. They can be hung on the wall or set on a shelf. Could even be incorporated into a speaker box for those into that. We have done the above among other projects. I have a guy that wants the Z28 made into door inserts. I will be doing those this weekend. Should look nice when lit up at night. Also going to do a third break light that will look clear until brake is applied then red Camaro will light up. Wait until you see what we are doing to a set of tail lights on the same car.
Old Jun 18, 2018 | 01:04 PM
Re: Lit Plates
The door inserts were finished and the guy completed his door panels and installed them. The Z/28 was fit into a pocket, so only the logo sticks through the panel and lights up. When the lights are off, it looks like a red emblem. He's thinking of doing the same to the dash, instead of a stick-on emblem.
I'll have him send some photos, so I can post them.
Old Jun 19, 2018 | 11:41 AM
prossi's Avatar
Re: Lit Plates
I have to ask what type of patent did you apply for because ive seen stuff like this being done for a long time?
PaceCarChris
Apr 25, 2012 05:36 PM
transam85dudeman
May 16, 2009 01:32 PM
redbird_400
Car Audio
16
Aug 2, 2002 10:15 PM
1987fbd
Jun 12, 2002 10:13 PM
87POSGTA
Jun 3, 2002 12:45 AM
