Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
My Cold Air Intake Rework
Old Feb 28, 2020 | 10:32 PM
Chad Speier's Avatar
Car: 1986 IROC
I decided to do some slice and dice. I measured it out and could raise the stock filter lid 3/4 inch. I also going to "ram air" the intake with a 4" system. It's been a mess but with the new engine I could literally hear it starving for air.
Old Feb 29, 2020 | 10:57 AM
skinny z's Avatar
Re: My Cold Air Intake Rework
I've always liked that idea. I was following another member's progress a few years.
https://www.thirdgen.org/forums/tpi/...pi-camaro.html
The only issue I saw with that approach is that the OEM sized filters are still somewhat undersized.
Testing I've read about states that 1 sq. in. of filter area is required for every 6-7 HP. One filter element is about 5.5" square (filter media only IIRC) with the combined panels equaling 60 sq. in. Based on that we're limited to an unrestricted filtering capacity of 420 HP.
Of course many have pushed more power than that through less but there is a limit.
Old Feb 29, 2020 | 11:02 AM
Car: 1986 IROC
The only issue I saw with that approach is that the filters are still undersized for anything north of 400 HP. At least that's the spec that's listed at K&N.
K&N is wrong, IMO. Look at what the new cars have. Single bolt on filter. This will have 50 sq/in of area inlet. Rule is 146cfm per inch.
Old Feb 29, 2020 | 11:17 AM
skinny z's Avatar
I was editing as you were replying.
I hadn't come across the 146 CFM guideline before. That's an enormous amount. (146 x 50!) Something I'll take into consideration if the cowl induction doesn't pan out.
Old Feb 29, 2020 | 11:19 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
that'll werk….
Old Feb 29, 2020 | 11:24 AM
427seven's Avatar
If you can, use silicone for the flex joint at the throttle body, the convoluted factory flex joints don't do anything to reduce air turbulence, although this would not be significant at other places in the system, it is right at the entry to the TB.
Old Feb 29, 2020 | 11:26 AM
skinny z's Avatar
I wouldn't accept that value if it wasn't a cylinder head airflow specialist posting it. Food for thought there Mr Speier.
Old Feb 29, 2020 | 12:33 PM
Car: 1986 IROC
Put it on the bench.
Before: 718@28" (Only get 10 and converted)
Now: 1155@28" (Only get 8 and converted).
Cleaned up and now a skim coat to make pretty..
Old Feb 29, 2020 | 12:34 PM
Car: 1986 IROC
Agree, got that handled as well.
Old Feb 29, 2020 | 01:22 PM
Billgluckman's Avatar
This fit under the factory hood? I’ve thought about doing something like this but was waiting until I had my hood back on the car so I could look at clearance
what filler is that?
Old Feb 29, 2020 | 01:50 PM
Car: 1986 IROC
Yes, under stock hood.
Evercoat Vette Panel Adhesive
Old Feb 29, 2020 | 01:51 PM
skinny z's Avatar
Are you able to run that test with the filters installed?
Old Feb 29, 2020 | 02:21 PM
Car: 1986 IROC
Filters made zero difference.
Old Feb 29, 2020 | 02:38 PM
skinny z's Avatar
Well, at 146 CFM per sq. in., that would make sense.
Old Feb 29, 2020 | 03:37 PM
Car: 1986 IROC
Old Mar 1, 2020 | 07:16 PM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
It looks like one of those inflatable flailing arm guys is looking your work over to make sure it's right.
Old Mar 3, 2020 | 04:40 PM
Car: 1986 IROC
SIZE XXL
Old Mar 7, 2020 | 02:24 PM
Car: 1986 IROC
Old Mar 7, 2020 | 02:44 PM
That’s awesome man. I really wish I had a complete tpi air intake. I’m missing the bottom part that actually holds the filters. At this point it’s cheaper to put together a “cai” than buy that piece though.
Old Mar 9, 2020 | 11:27 AM
Car: 1986 IROC
I haven't got on it real hard, but it's a complete beast.
https://youtu.be/HcaX0OzGs0k
Old Mar 9, 2020 | 12:56 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Not putting you down, but wouldn't it be better to run that "ram air" setup like Hawks sells over those convoluted tubes, especially since you haven't closed off the sides of the inlet area? Or are you only looking for a solid path for cold air?
Old Mar 9, 2020 | 01:20 PM
Car: 1986 IROC
What Hawks sells is nowhere close to a "ram air" it's big ole slow box.
Closed off what sides? Lost me there.
Old Mar 9, 2020 | 01:25 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
On the sides of the grille opening where the convoluted tubes are, you can see the radiator. I guess by your replies you're only looking for cold air not not "ram air"
Old Mar 9, 2020 | 01:45 PM
Car: 1986 IROC
That would be ram air. It's 4" pipe raming the air into the lid.
Cold air would be hanging one of those ugly tubes off the TB and pointing it towards the ground with a filter on the end.
Old Mar 9, 2020 | 01:50 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
umm, ok
Old Mar 9, 2020 | 01:53 PM
Car: 1986 IROC
umm, ok
Don't agree?.. Look at a NHRA Pro Stocker
Old Mar 9, 2020 | 02:18 PM
Im genuinely curious about what hawks product you’re talking about
Old Mar 9, 2020 | 02:21 PM
Car: 1986 IROC
https://www.hawksmotorsports.com/cam...ram-air-boxes/
Old Mar 9, 2020 | 02:50 PM
lol that’s new to me. Looks like something that belongs on on your home.
Old Mar 9, 2020 | 09:08 PM
skinny z's Avatar
The "house" ducts fill the grille area of the IROC. It looks sort of DIY but I can see how it would yield results.
In the OP's case, it looks to be a pair of ducts from the Speedway Motors catalog. The kind of thing that makes it's way on to the circle track cars. I'm guessing, but I'd say that's a 90° inlet fitting in the grill and then up (through the corrugated tubing) to the filter housing. Very effective. And it doesn't look like it came from Home Depot.
EDIT: I see it's not a 90 fitting as the pipe attaches directly to back of the "frame". But the result is the same. Ram air. Fresh air.
Old Mar 9, 2020 | 09:33 PM
Car: 1986 IROC
Old Mar 10, 2020 | 12:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Indeed it is ram air when it develops pressure at the filter box area at speed. If the duct is sealed to the filter box it will get air pressure
looks like it will work great. Would be nice to see the power difference tho, before and after
Old Mar 10, 2020 | 12:14 PM
skinny z's Avatar
...with the new engine I could literally hear it starving for air.
Before and after!
Old Mar 10, 2020 | 12:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
All due respect i am a numbers guy. I trust Chad tho, but i just like to see quantifiable data. Also wanted to see actual drivetrain loss from engine dyno to chassis dyno lol always been my curiousity
Old Mar 10, 2020 | 12:39 PM
skinny z's Avatar
That was a little tongue in cheek there Mr Orr. If you know anything about me it's my pursuit of quantifiable data. I'm a numbers guy too. I'd prefer a little more hands on at the moment but that'll have to wait.
Still, what Chad has built is something I've considered pursuing for a while. That or cowl induction.
Old Mar 11, 2020 | 09:56 AM
Car: 1986 IROC
I need to get the tuner online before I go through the gears.
I agree with Orr, wouldn't that be something if it was creating a little boost!
Old Mar 11, 2020 | 11:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
add another map sensor to the holley and plug it in there
Old Mar 11, 2020 | 07:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I can't see the video, but it's mean looking setup Chad.
Old Mar 12, 2020 | 09:15 PM
Car: 1986 IROC
I swear it's pulling major air. I think I can hear it. Tuner told me to take a drive tomorrow. If my MAP is 101 I did good. If it's over, I'm a bad ***. lol
https://www.youtube.com/watch?v=Q7GGS4z3rfQ
Old Mar 13, 2020 | 04:59 AM
Which gauges are you running? Dakota digital I assume but I’m not sure what all is actually available.
Old Mar 13, 2020 | 09:13 AM
Car: 1986 IROC
Old Mar 14, 2020 | 02:31 PM
  #42
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I made some measurements several years ago(355 engine ~400hp) how much pressure ram air makes,at this thread,post #8 https://www.thirdgen.org/forums/tpi/...o-85-92-a.html
Old Mar 14, 2020 | 03:28 PM
  #43
Car: 1986 IROC
I can't drive it due to weather but looking over old logs before the rework, it was showing 87 kPa at WOT. Which means I had lots of work to do.
Old Mar 14, 2020 | 03:37 PM
  #44
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Oh wow. Yeah 87 is way down. This should greatly pick up even if it gets to mid high 90’s kpa
Old Mar 14, 2020 | 03:39 PM
  #45
Car: 1986 IROC
Part of me wants a mono blade.
Old Mar 14, 2020 | 03:48 PM
  #46
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oh my gosh, that engine was gasping for breath! Ya, I'll bet you do feel a big difference.
Old Mar 16, 2020 | 02:45 PM
  #47
Car: 1986 IROC
I'm not 100% sure here. I'm at altitude. When I turn my key on, I'm reading 93 kPa, not started.
Would I ever show 101 kPa at altitude?
Old Mar 16, 2020 | 02:49 PM
  #48
skinny z's Avatar
I'm at 3000 feet altitude and the barometric pressure at the moment is 102.1 kpa.
Old Mar 16, 2020 | 03:24 PM
  #49
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You can look up historical min & max barometric pressure for your area.
Old Mar 16, 2020 | 03:31 PM
  #50
Car: 1986 IROC
I've done enough racing with gauges to know it can't ever be 101. We are not sea level.
