Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Pro Flo 4 XT
Old May 27, 2021 | 02:45 PM
DuaneB's Avatar
Pro Flo 4 XT
Hey looking for a little help out there please. I’m installing the Edelbrock Pro Flo 4 XT. Just wondering if anyone had. Having issues with throttle cable and thermostat housing as the suggested one points right at my alternator. Any help would be appreciated thx
Old May 27, 2021 | 11:09 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Pro Flo 4 XT
When i helped my friend with his install we had to get a different thermostat housing cause the original one interfered. We used a lokar throttle cable. I will try to find the part numbers
Old May 28, 2021 | 08:20 AM
DuaneB's Avatar
Re: Pro Flo 4 XT
looks great. The problem I’m having is I have air conditioning and my alternator is on drivers side. I notice the pedal doesn’t give you full throttle did you have to modify?
Old May 28, 2021 | 10:20 PM
Car: 1984 T/A
Engine: LQ4
Re: Pro Flo 4 XT
This car has aftermarket accessory brackets. We used a lokar adjustable throttle cable.
Old May 28, 2021 | 10:22 PM
DuaneB's Avatar
Re: Pro Flo 4 XT
do you use stock pedal. I can’t seem to get full pull. I have Lokar cable as well
Old May 28, 2021 | 11:10 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Pro Flo 4 XT
What was the transmission? 700R4? If so, what did you do for TV cable?
Old May 29, 2021 | 10:03 PM
Car: 1984 T/A
Engine: LQ4
Re: Pro Flo 4 XT
Stock gas pedal. IIRC edelbrock has their own cable bracket that we used. This vehicle has a t56
Old May 29, 2021 | 10:14 PM
DuaneB's Avatar
Re: Pro Flo 4 XT
we have bracket on side of intake but still can’t get full throttle what cable did you use ? Lokar part #?
Old May 29, 2021 | 10:39 PM
Car: 1984 T/A
Engine: LQ4
Re: Pro Flo 4 XT
we used this with the same throttle cable used for ls swaps
Old May 30, 2021 | 07:56 AM
JaredAbrahamson's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 gen 1 SBC, Pro Flo 4 XT EFI
Axle/Gears: 3:70 Ford 9 inch
Re: Pro Flo 4 XT
We used this cable, and the bracket that punkmaster showed, using the stock pedal we were able to get it perfect
turboguard
Jun 7, 2017 01:21 AM
jaypug92
Jul 30, 2011 03:27 AM
ManicMechanic88
Members Camaros
May 15, 2008 07:00 PM
ZROLimitRacing
Carburetors
Sep 3, 2007 09:04 PM
