edelbrock 1406 help...
Old Aug 28, 2007 | 12:18 AM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
just bought a edelbrock 1406 and was wondering if anybody could help me out with finding some brackets for the throttle and TV cable. part numbers, pics anything will help.
Old Aug 28, 2007 | 01:27 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Re: edelbrock 1406 help...
Do a search on Summits website or check out Edelbrock.com under general installation items. They have a fairly long list of part numbers.
Old Aug 28, 2007 | 02:32 PM
did that and didnt find much of what i was looking for, anybody else?
Old Aug 28, 2007 | 02:59 PM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
i had that on my bird with the cheap spectre chrome lil bracket that mounts on the back nut of the carb... cheap but works and adjustable... can use kick down cable i think
Old Aug 28, 2007 | 06:51 PM
elky74's Avatar
Did you check the Edelbrock site under "installation items"? Some of the part numbers are 8030, 8032, and 8036 right off the top of my head. I think 1 or 2 of those are supposed to be universal, which is what I got. Not sure how it's going to work, though, since I haven't installed it yet (in the middle of an engine swap).
Also, at Summit, just type in edl- and the part number you want and something should come up. Jegs is also a good site for these parts.
Old Aug 28, 2007 | 07:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Summit numbers......
For the cable bracket - go with EDL-8030 - it's a nice chrome bracket, totally adjustable, and it's nice and sturdy - very very little flex - well worth the extra cash over the Spectre crapola.
Assuming you have a 700R4, you'll also need an EDL-8018 to connect the TV cable to the carb.
One last requirement if 700R4 - You'll need a TCI-376710 to correct the geometry for the TV cable. You'll connect the EDL-8018 to this.
You'll also need a banjo fitting EDL-8089 more than likely - the drop-based air cleaner housing that you must use to fit all under the hood will not go completely in place unless you swap to a banjo fitting for the carb (instead of the stock carb fuel fitting on the 1406).
That's what I used on my 1992 carb swap car, and over a year later all is well!
Old Aug 28, 2007 | 10:39 PM
camaronewbie thanks alot, you dont have any pics of this setup you can put up for my viewing pleasure do ya?
Old Aug 29, 2007 | 01:46 AM
elky74's Avatar
I went with EDL-8031 and the 8018 throttle lever stud. I hope the bracket holds up ok.
Old Aug 29, 2007 | 01:55 PM
Car: 1992 RS
Engine: Carbed 350
I'll see what I can do about pics - might take me 'til the weekend - I can work the camera, but the wife is the master of getting them on the pc
Old Aug 31, 2007 | 11:27 AM
RLZ28's Avatar
Car: 84 Z28
Hey,
I'm running a 1406 with a 700r4 as well.
I purchased a Bracket from "PACT" Cost is $35.00 Picture is below it worked well for me.
They also sell a longer TV Cable if needed and several brackets.
Here is a link to the web Page
http://www.transmissioncenter.net/highperf700r4.htm
Old Sep 3, 2007 | 09:04 PM
ttt
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
R13_Braz
Sep 18, 2015 05:00 PM
