[NJ] Feeler: 1991 Firebird Vert MANY Upgrades
1991 Firebird Convertible 5.7 TPI
So I am considering selling my 1991 Firebird Convertible. The body has about 195k on it but the entire car has been completely redone about 2000 miles ago. I just dont use it much, I built it back in 2012 and have only put about 2000 miles on it since. I used to keep it in storage but the price went up so then I moved it to my shop and pull it in and out every day but its just kind of getting in the way now. Id like to find it a home where someone can enjoy it. Problem is I have so much invested in this car (well over $20,000) that I would need to get a pretty penny to let it go. Below is a description and ill add a ton of pictures. Id like some thoughts on what someone would think its worth. Id probably let is go for $10,000. Its an awesome car.
Upgrades:
52mm Throttle Body
Ported Intake Plenum
Ported SLP Runners
TPIS Big Mouth Lower Intake
Crane Cams 2032
Rebuilt bottom end with 2000 miles on it
Upgraded L98 cylinder heads
Crane Adjustable Fuel Pressure Regulator
22lb/hr Bosch Fuel Injectors
MSD 8366 Distributor
MSD Ignition Wires
MSD Street Fire Ignition Coil
Jet 180 Degree Thermostat
Speed Density Fuel Injection System
EBL P4 Flash ECM
Walbro 255LPH High Pressure Fuel Pump
700R4 Rebuilt 2000 miles ago and upgraded
Dayco 2300-2500 Stall Speed Torque Converter
Borg Warner 9 Bolt Rear rebuilt 200 miles ago 3.45 ratio
Bilstein Rear Shocks
KYB Front Struts
Founder Performance Rear Panhard Bar
Founder Performance Rear Lower Control Arms
Welded In ALston Subframe Connectors
TDS Wonder Bar Steering Brace
Hooker 2055 Headers and Y Pipe ( y pipe cracked and needs to be replaced)
Magnaflow 3" Exhaust
4 Wheel Disc Brakes
Big Brake LS1 upgraded Front Brakes
16X8 WS6 Wheels
A/C has been deleted
Needs Repairs:
Y pipe is cracked and needs to be replaced
Rear main seal leaks a little, has since I put the motor in.
Brake pedal feels mushy - iv been trying everything to get the pedal to feel more firm, but im comparing it to my 2002 Mustang GT and my 2019 Ford Edge which you touch the pedal and it nearly puts you thru the windshield so my expectations might be skewed after all it is a 1991 car. I think maybe the rear calipers need to be done over.
Dash has the classic crack in it.
Upgrades:
52mm Throttle Body
Ported SLP Runners
Crane Cams 2032
MSD Ignition Wires
EBL P4 Flash ECM
KYB Front Struts
4 Wheel Disc Brakes
16X8 WS6 Wheels
Needs Repairs:
