Group Purchases Take part in, suggest, or discuss Group Purchases here. Make sure to read the rules before doing so.
Custom Side Marker Lights!
Old Oct 18, 2013 | 08:38 AM
  #101
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: Custom Side Marker Lights!
If youre concerned ask for a refund.
If no response contact paypal and start a dispute.
If you disnt pay with paypal, potential lesson learnt, protect yourself and utilize paypal.
I might add that these are formed from gm marker lights so im sure they fit well.
Theyll sure look great on our pontiacs!
Old Oct 19, 2013 | 09:28 AM
  #102
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Any ideas yet on how to safely remove the old markers from their housings and fasten the new ones?
The third brake light lens wouldn't be such a problem, since it screws right on.
Old Oct 19, 2013 | 10:42 AM
  #103
Stangski09's Avatar
Heat gun and fishing line, like removing emblems.
Old Oct 19, 2013 | 11:59 AM
  #104
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Most likely you will ruin the original lens; you want to make sure the housing is kept intact and clean it up to make sure it's all flat before installing the new lenses.
When I did my rear ones I carefully pried the old lens off (you can see where they been glued together from the factory) and got them off but in a few large bits. Then used a dremel to clean up the housing properly before putting the new lenses on the housings.
I would just pick up a nice used set of marker lights and use those (that's what I did) and put your originals away just in case you want to swap back at some point in time.
Old Oct 19, 2013 | 04:14 PM
  #105
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Good advice, guys. Thanks.
I'll look for some spares if the lenses arrive some day.
Old Oct 20, 2013 | 04:05 AM
  #106
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Thirdgenranch is a good cheap source; this is where I bought the ones (rear marker lights and 3rd brake light) that I had sent directly to Jason @ Klearz.com to make the molds from.
http://www.thirdgenranch.com/catalog...934bd91be00589
Old Oct 22, 2013 | 05:33 PM
  #107
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Is someone actually in contact with Jason at the moment?
Old Oct 23, 2013 | 05:57 AM
  #108
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
I had email communication with Jason last week with prompt response from his side.
Will hopefully get my 3rd brake light lenses this week
Old Nov 7, 2013 | 07:58 AM
  #109
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Wow.
I finally did get my lenses, even though I never again received any reply to my emails.
So here are some pics.
I ordered smoked amber and smoked red lenses.
IMO, the castings needed some minor refinement, so I treated them with some sanding action around the edges and the backside to get smooth sealing surfaces.
Two of the lenses were strangely warped, even though they came wrapped up very carefully.
Got out my regular hair dryer and applied whatever heat it could give so the lenses would sink into an even form.
They visible lens areas btw are perfectly smooth, no scratches, nothing that needs correcting.
I'm waiting for an extra set of sidemarker housings to attach them to. Perhaps I'll give the housings a chrome spray treatment first, we'll see.
Attached Thumbnails Custom Side Marker Lights!-p1000133a.jpg   Custom Side Marker Lights!-p1000135.jpg   Custom Side Marker Lights!-p1000138.jpg
Old Nov 14, 2013 | 05:11 PM
  #110
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Ok, so there's another catch on the front markers. The lenses are usually different ones for left and right casings, the difference being the location of a tiny bulge below the visible area.
There's a part of the fender in the way, so the driver's side lense needs to be trimmed in that area.
The smoked amber lenses turn out to give a slight red tint to the emitted light.
I do not envy anyone who has to separate old lenses from their housings. That was a PITA to do!
Old Nov 20, 2013 | 05:38 AM
  #111
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
The rears also usually have a left and right side... these lenses do not and they need to be carefully adjusted, plus the holes need to be redrilled for the frames to go through.
I highly recommend getting an extra set of side markers and not experimenting on the old installed ones, because the stock lenses are always glued on to the casings differently and tend to break in several places.
Look nice, though. Will try brighter bulbs, because they are also rather dark.
Old Mar 27, 2014 | 01:24 PM
  #112
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
How did the brighter bulbs turn out?
Old Mar 27, 2014 | 03:19 PM
  #113
Stangski09's Avatar
Looking great!
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
