whats the weight of this car?
Old May 13, 2002 | 11:19 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
its a 305 tbi v8 91 firebird hardtop, power windows, locks . . .
thanks
Old May 14, 2002 | 12:39 AM
Guest
Guest
Posts: n/a
Wild guess? 33-3400lbs.
Old May 14, 2002 | 02:33 AM
Gibby85's Avatar
Car: 85 IROC-Z
Engine: 305 TPI (stout rebuild)
Transmission: TH700R4 w/2200 stall
Should say gross weight on the inside of the door.
Old May 14, 2002 | 03:04 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Its like 1,830 Killios
Old May 14, 2002 | 09:12 AM
raptoryfm660r's Avatar
91fbirdgta,
I would think the weight of the car would be very close to mine.
Looking at the certificate of origin from GM it states the shipping weight as 3429 pounds.
madmax was really close on his wild guess. madmax could you give me some lottery numbers, only be exact please.:hail:
Chet
Old May 14, 2002 | 09:32 PM
91fbirdgta's Avatar
wow only 3429 lbs! my gta weighs 4225 or something close to that- but what the dramatic weight difference? its almost a 900 lb difference . . .any ideas
thanks guys
Old May 14, 2002 | 09:49 PM
91fbirdgta,
Your weight can't be right. I pulled an old Motor Trend from July 1988. They did a test on the then new GTA. The published weight is ( 3604 lb ).
Chet
Old May 15, 2002 | 10:10 PM
91fbirdgta's Avatar
raptoryfm660r-thanks, that sounds like a relief! maybe I read it wrong on my door panel the last time i saw it , its on the drivers side door right?-it has the front weight and the rear weight and then the total-thats the slip to tell you right?
I'll check it again in the morning-
Old May 16, 2002 | 10:12 AM
Guest
Guest
Posts: n/a
The sticker on the door is the GVW, gross vehicle weight. That includes passengers and luggage, the max load you are supposed to put in the car, not the actual weight.
Old May 16, 2002 | 10:46 PM
91fbirdgta's Avatar
yep-thats what I was looking at-thanks madmax!
its good to hear my car isn't that heavy!
Old May 17, 2002 | 12:23 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
everyone thinks that the weight stamped on the door frame plate is what is the actual weight of the vehicle. i do not know why people think this, GVW is the total maximum combined weight including all luggage and passengers that the vehicle can weigh, if you surpass it then it is overloaded by law.
1/2 ton trucks are anywhere from 5,000 to 6,200 or so.
3/4 ton trucks are 7,500 and up and 1 ton are 10,000 and up,
most 70's-older caddies are 5,000-up also
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
