T-tops and 1990
Old May 22, 2002 | 03:07 PM
Omar's Avatar
T-tops and 1990
According to the White Book, you could NOT get T-tops and a manual tranny in 1990.
Have you guys found this to be pretty accurate? I know I have caught little errors here and there with the White book.
I was hoping to find a 1990 IROC-Z 305/5spd with T-tops to drop in a ZZ4 and possibly a T-56 in the near future. I guess I will have to go auto.
Old May 22, 2002 | 06:13 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You might have missed something. You could not get a 350 with ttops or a 5 speed. I think you could still get T's with 305 5 speed cars in 90.
Old May 22, 2002 | 11:20 PM
Omar's Avatar
Not according to the White book, which is my point. (and question)
Does ANYONE have a 1990 Camaro 305/5spd with T-tops?
Old May 23, 2002 | 12:07 AM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I'd assume you could get the 305/5speed with t-tops in 90 as you could go G92 305/5speed with t-tops 91-92... which is what i'd like to get a hold of... Black or Blue
Old May 23, 2002 | 12:26 AM
Omar's Avatar
According to the White Book, you can't do that in 91 or 92 either.
CC1 not available with manual tranny or G92, in 90-92.
Old May 23, 2002 | 11:33 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Hmmm... I don't want to start a huge argument here, but i've seen a dual cat, rear disc brake 305 5speed with t-tops (91/92)... I don't know though, i'll just assume someone messed with it... but i'll hope they are out there....
Old May 24, 2002 | 12:22 AM
Omar's Avatar
Demon, you will definitely not be starting an argument with me. Maybe with the White Book. But not me.
I am just trying to verify if this is correct or not.
Old May 24, 2002 | 12:25 AM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I just know how i've seen some topics blow up over option issues... Anyway, now that it could be disputed, I definetly want to know as i've always thought you could get a 91/92 305 5spd G92 with t-tops and that's what i've been trying to find. I need to get a white book
Old Jun 1, 2002 | 11:16 PM
92TRANSAMWS6's Avatar
My Trans Am is a 305/5speed with T-tops.
Old Jun 2, 2002 | 06:47 PM
Omar's Avatar
How about anyone with a Camaro?
Old Jun 2, 2002 | 10:15 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Does your T/A have 4 wheel disc brakes? 3.42 rear? etc...etc...? That's the main thing here. I've been finding plenty of 305/5speed t-top 91/92's, but none are G92 equiped.
Old Jun 3, 2002 | 09:13 AM
92GTA's Avatar
Speaking for T/A, in 91& 92 if you got the 305/5-spd you automatically got R6P/G92 unless you deleted it. T-Tops had nothing to do with this. The only reason I don't have it is again, it only came standard on the 305/5-spd combo, not with the auto.
Old Jun 3, 2002 | 12:20 PM
dgoodhue's Avatar
My friend ordered 91 Z28 new 1991. He couldn't order a T-tops and the H.O. 305/5 speed or 350/auto. I assume by High Output he meant G92, a RPO code probably wouldn't have made much sense to us then....
Old Jun 3, 2002 | 04:37 PM
Kandied91z's Avatar
not that this will matter much, but i've seen the 305 manual with t-tops many times........stock, restored, modified; they are out there.
it's only the 350 that is a hard case.
if your car had a 305 you could have t-tops no matter what in any year.
Old Jun 3, 2002 | 06:32 PM
v8powr's Avatar
My camaro is a 90 with ttops and 305tbi 5speed with a 3.08 posi rear (drum). It was originally med maui blue metallic. Any other questions? It also has the iroc hood. It was an ordered car meaning it was not bought off the lot.
Old Jun 3, 2002 | 06:52 PM
Omar's Avatar
I guess the Bible was wrong.
Old Jun 3, 2002 | 09:37 PM
Yes it does
Old Jun 4, 2002 | 11:01 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Originally posted by 92TRANSAMWS6
Yes it does
Then who knows... The Pontiac's are probably all differen't.
Old Jun 4, 2002 | 11:06 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Some people had aftermarket T-Tops done when they weren't available.
Old Jun 5, 2002 | 08:19 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 2, 2015 09:12 AM
