83 Z\28
83 Z\28
Just a little question about the l69. I've been doing some reseach,
If i get my rpo tag off my car you guys should be able to decode for me.When i get home i post the codes. I will tell what it does have for sure.
305 (carb)
5 spd t-5
t-tops
disk brakes on rearend
power locks,windows,seats
Thanks guys.
305 (carb)
5 spd t-5
t-tops
Thanks guys.
Car: 4
Engine: 6
Transmission: 5
You don't need to bother with finding the RPOs, just look at the VIN. 8th digit should be a 7 for a L69 car(that's what mine is anyway), and of course it should have HO badges inside and out, electric fan, 3.73 gears, the big exhaust with the cat with a 4-bolt flange on both ends, etc. Altogether different from a LG4 car. If your car has any other gears, clutch fan, or the small exhaust, or a H for the 8th digit, it isn't a HO.
What is your question?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
how did it get disc brakes ? does it have glass hood ? i ask cuz ive had an 84 Z28 L69 and it had drum rear, but were aluminum drums
and had an 83 Z28 LG4 and it had glass hood and iron drums rear
not sure how yours has discs rear ?
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
The 83Z I gave my son a few months back has all the stuff listed in the notes above (except the 5 spd) but has a metal hood. When a car comes down the line and needs a part it probably gets what ever is available. Unless it was special ordered you buy what is on the lot so you get what you got. How are you going to complain about it not having some special part on it 15 or 20 yrs. later when people start getting interested in "collecting" those vehicles?
Car: 4
Engine: 6
Transmission: 5
IIRC all of the 83 Z28s came with the composition hoods. There was a recall on them though, for delaminating at speed. Quite a number of them were replaced with metal ones under that program.
Disk brakes were not part of the HO package, they had to be ordered individually, and were available with any of the motor packages. Obviously very few of the people that were interested enough in performance to go to the dealer and order a "performance" car with a "performance" brake package would have ordered such things on a base engine LG4 car, so the huge majority of the cars from back then that ended up with DBs were either CFI or HO cars.
My 83 HO car had drum (aluminum) brakes.
Probably the only option available for it that it didn't come with. It now has 91-92 PBR disk brakes.
It came with velour interior, T-tops, power windows, seat, mirrors, hatch release, antenna, & door locks; the better suspension; the better radio; in short, everything except disk brakes. Go figure.
