Foglight Replacements
Old May 11, 2003 | 07:04 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I was wondering if these foglights I found off of ebay today would fit my 86 trans am? They came off of a 87 Trans Am GTA. Is the wiring and bulb connections and size of the lights the same as mine?
Old May 12, 2003 | 10:59 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Yes, those fog lights will work fine for your T/A. All fog lamps from 1985-1990 will interchange between W68 Firebird, T/A, and GTA models.
Replacement lamps are available from WalMart under the name "Blazer OEM Driving Lights" for $19.96 per pair. The lamps will mount directly into the factory brackets. The wires must be spliced into the fatory wire, but other than that they are a direct fit replacement.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
