Questions about gauges
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I have an 88 Roc and I saw on the IrocZone.com history of Irocs that my 305TPI should have the 145 speedo. But really it has the 115 I do have the 5500 redline though anybody know why. Its a real Iroc i ran the RPO's a while back and its came with the TPI.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
5500 redline is right... only the L69 (4 barrel HO) had a higher redline @ 6000 (factory says 6000, tach says 5500).
As for the speedo... there were different ones available for the same cars in the same years.
I've seen at least 4 different speedos for '83.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Something doesn't seem right....
I thought 305's had a 5000 RPM redline; the 350's had the 5500 RPM redline.
My '87 IROC (305) has 145 MPH speedometer with a 5000 RPM redline tach.
Nope, all the V8 cars had a 5500 redline on the tach and a 5000 yellow-line, i'm sure.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
peanut cam 305s had 4500 yellow and 5000 red lines. i heard that all 350s had 145 speedos and 305 TPI cars with 3.23 gears had 145 speedos. All other 305 TPIs had 115. I am not sure about manual cars. And i know 85 the highest was the 85 speedo.
Kevin
Kevin
Car: 88 Iroc
Engine: LB9
Yea I know its not the G92 it had a 3.08 posi when I blew it. Everyone just seems to have the 145 speedo and I was wondering why I didn't.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have a G92 '87 IROC w/305TPI and 700R4 (which also meant, peanut cam).
My speedo is the 145mph and my yellow line on the tach is at 4500 and the redline is 5000.
See???
See???
See???
See???
Car: 88 Iroc
Engine: LB9
But my tire guide on the inner door panel says 245/50/16 and the speedo goes up to 115 not 110. I dunno maybe they just messed up?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No IROCs came with the 235 tires. Only the RS cars with 16" wheels got those. All IROCs with 16" tires got 245 50 16 tires.
Ghettobird52
Jul 5, 2024 11:18 PM
