assembly plant?
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
paint
I'm 99 % sure it was just paint quality.van nuys was in California which had stricter EPA standards and had to you enamel water based paint .norwood plant had better paint that almost bonded to the paint better.Hopes this helps
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The paint wasn't better because it was a slower line, its because the "bad paint" was water-based and is crap. The other is good oil-based paint. They also had a better painting process.
I just said the Paint & Quality was better and not because the line speed was slower. I am a original owner of a 87 Norwood car.
Originally posted by DJP87Z28
The Norwood, Ohio assembly plant had better paint & quality due to a slower assembly line vs the Van Nuys.
ok
and I am also an original owner of a 87 Norwood car... but my dad got into a slight accedent and the hood was repainted... and now is crap! dam 80/ early 90's paint!!!
Originally posted by Mr. TurboTA
Gee,
Then why did they close Norword??? Because it was better????
George
Gee,
George
model year. The 4th Gen production was moved to Canada and it also suffered the same plant closing in 2002. That is the short history.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It has been said by a few people that the build quality of the Norwood cars is better. Not only due to the better paint facilities but just the quality of the assembly usually came out better. That is until mid to late 1987 where it dropped sharply.
Now this so called better quality build isn't enough to make you want to go out and specifically get a Norwood car. It's not that big of a difference.
The paint was only better because stupid California air laws made the aresol style paint illegal. So they had to use a different base which didn't last as long or adhere to the cars as well.
The Van Nuys facility stayed open because it was more modern and cranked out cars alot faster. I think it was cheaper to operate as well due to being tooled better.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Originally posted by bigals87z28
not to mention.. the original first camaro plant... Just to think my car passed through the same area as a 69 Z28 or a 396 SS..
Why specifically an 87? Why do you want an 87 so bad? Theres not much difference from 87-90. Minor differences in 1991 and 1992.
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
hey guys
i have a 1988 SC2 optioned camaro 305 tbi the works lol.
anyhow the production date is 7-87 i think. Where can i find the info on where the car was built at meaning what factory.
also at what part of the yr did they offer the 305 tbi in 87? for the 88 model yr?
You can find the Assembly plant in your Vin, should be the last letter (N) Norwood & (L)Van Nuys before the last five numbers.
The L03 (TBI) was offered in the 1988 model and not before.
You can find the Assembly plant in your Vin, should be the last letter (N) Norwood & (V) Van Nuys before the last five numbers.
Van Nuys = L
skinny z
Oct 5, 2015 06:23 PM
Dragonsys
Sep 25, 2015 03:51 PM
