rear end?
Old Aug 13, 2003 | 04:15 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
rear end?
What type of rear ends came on the 85 Z 28's? Its not posi right? I cant find the numbers coz the axle is covered in rust and its on the car.
85 Z 28, 305, 4BBL, non ECM
Old Aug 13, 2003 | 04:46 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
If it's an automatic 3.08, manual 3.23, according to the Camaro Techical Database.
Posi was a stand alone option that year so it could be (but not likely) a posi rear end.
Old Aug 13, 2003 | 06:41 PM
demonchild's Avatar
there is an easier way to tell....lay some rubber down.
Old Aug 13, 2003 | 06:56 PM
_max_'s Avatar
<--------hehe
Old Aug 14, 2003 | 01:00 AM
2 dope's Avatar
Engine: 305 LG4
lol ya but ive never driven a posi so i have no clue what its like
Old Aug 14, 2003 | 01:57 PM
demonchild's Avatar
i dont think you caught my drift. stand on the brake and gas at the same time and see if there is two tire marks on the pavement instead of one.
Old Aug 22, 2003 | 12:19 AM
2 dope's Avatar
Engine: 305 LG4
well i did a brake tourque, only got one tread on the right tire, darnit, i was hopin for posi...is there anyway to make it posi, like putting in new gears or somethin?
Old Aug 22, 2003 | 12:16 PM
bes217's Avatar
Instead of doing that you should o to whe wrecking yard and find a rear end that is already posi and then just swap the rear ends. Assuming that your car and the new rear end have the same type of brakes it is a direct swap.
Old Aug 22, 2003 | 03:25 PM
demonchild's Avatar
i think you need to reasd more on how rear ends work and what came stock for certain years. the tech section would be a good start.
as for the posi...slp sells some pull offs for 100 bucks.
Old Aug 22, 2003 | 03:36 PM
2 dope's Avatar
Engine: 305 LG4
i have the basic knowledge of how they work. Ive just never worked on a differential before.
Old Aug 25, 2003 | 02:43 PM
82camaro's Avatar
Car: 82 camaro SC
SLP ones will require different axles than what you have. Pop the cover and take a look. Tire marks don't mean much. Before the locker mine would sometimes burn both tires without posi. Also, a worn posi may only leave one mark. You could get a whole rear from a junkyard and hope it's not worn out or nearly worn out--overtime they will wear out.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
