Any 350's ever made with manual trans?
Car: 4
Engine: 6
Transmission: 5
Yes it is true.
None of us that I know of were there at the time the decision is made, so we don't know for sure. But 2 likely causes were warranty / reliability issues, and difficulties with emissions certification.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's true, but just watch someone come along and deny it. Some people say that it was because GM couldn't warranty the T-5 behind the torque of the 350. More likely it was because they couldn't emissions-certify it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the closest guess we have is that since the T5 was rated so low for TQ, and a abusive person with a 305 could easily break it, with a 350 in front of it, esp with how torquey the TPI350 was, it would cause reliability issues
so rather then make them and have them break, they made all 350s autos
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by 91zconvt
I still think it's because it would of made the 3rd gen as fast as a vette at the time, and we all know GM would never let that happen...
Both were obviously faster than the vettes of the same year... much faster. The L69 murdered the Corvette in almost every category except maybe handling, but it killed it in every speed related category. The TTA could run low 13's stock. The vette never did untill the LS1 came out. Enough said.
I think GM never put the 5 speed behind the 350 because of emitions as well.
If it was a durability issue, it never would have been behind the 305 either.
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
The Vette got a six speed manual but I really like Porsche's idea of a Tiptronic for those leaning towards autos but maximizing the control the manual offers.
I prefer autos for simplicity and having an arm and leg free (or not) I do tend to do things in the car...like eat or drink that shifting makes a challenge.
I always felt the 350 with auto was a safety concern but also because of insurance on F cars (my belief)
They felt the bigger block was watered down for the audience the car catered to, unlike the Vette that is more mature and upscale. Cadillac suffered in the same regard due to the stereotype of owners but I've found Cadillac sales people to be awesome...they really get to know the customer, at least in my case...even when only going for parts. I've had a pleasant experience ...for them the performance issue HAD to be addressed for a marque getting long in the tooth but once considered The World Standard
-B
Bill
-B
Bill
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Originally posted by Air_Adam
On paper, that can GM will never let it happen... but remember the L69? 10hp less than the vette. The TTA? 10hp less than the vette.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I broke the 5spd in my L69 car a couple of times, even a World Class once.
Have to remember, the only manual trans for the 350 in the '80's was a T10(Doug Nash enhanced) and the ZF 6spd. Those were plenty strong enough to handle the torque of the 350.
Originally posted by 86WS6_T/A
I got the point of your post but just wanted to remind you of the big block vettes in the mid sixties. I believe the 66 w/ the 427 ran a very low 13 sec e.t.
Just for the record... the '66-70 Big block cars (427 and 454) ran high 12's with only slicks. In stock trim they ran in the 14's, but thats because of the garbage bias-ply tires they came with.
ok, if they couldnt put the t-5 behind the 350, why did they put it behind the 305 wiht the l98 cam that made MORE POWER!! the 305 with teh l98 cam made a little less power then its bigger bore brother.
T-5 in a 350 would of been nice if it was a little stronger.
And im sure that there were LT1 6spd vettes running low 13's since they run mid to high 12's witha 6spd ls1.
Originally posted by iroc22
What about the Doug Nash 4+3?
Warranting that trans made Doug Nash go out of business. Had to sell the 4+1 to Richmond to break even. Then closed the doors.
That's why I said Doug Nash enhanced. It was a Borg Warner T10 with an overdrive unit attached.
Yeah that tranny had its share of problems. Most guys I know with Vettes that had the 4+3 have swapped it.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Originally posted by bigals87z28
ok, if they couldnt put the t-5 behind the 350, why did they put it behind the 305 wiht the l98 cam that made MORE POWER!! the 305 with the l98 cam made a little less power then its bigger bore brother. T-5 in a 350 would of been nice if it was a little stronger.
A T-5 will NOT last behind a 350 TPI that is driven aggressively, they barely handle the better 305s and sometimes even don't. Originally posted by IROCZTWENTYGR8
I'd say the approx. 15 more HP and almost 50 more ft./lbs. of TQ had something to do with it.
A T-5 will NOT last behind a 350 TPI that is driven aggressively, they barely handle the better 305s and sometimes even don't. that still doesnt explain to me why the 305 5spd got the more agressive cam when the auto got the crap if the auto could hold more? just doesnt seem right to me. I think a 5spd in the 190hp 305 would of made it feel faster!! Then there is the whole thing that why did GM continue to make the 305 at all after they 350 came back? And why so many variations? Should of been 350 TPI, 305 TPI and the 6cyl IMO.
I guess the auto version of the LB9 got the weaker cam because the 5-speed version was considered the high performance version so they gave it all the goodies.
Yeah. The 5-Speed LB9 was more of an enthusiats 305 I guess you could say.
The Third Gen and the Gens before it were about choices and it was 1 of the things that made them so successfull.
The Third Gen and the Gens before it were about choices and it was 1 of the things that made them so successfull. As for the cam choose manual cars allows had a better cam than autos. As for the Vette vs Camaro the Camaro was know to be fast form 67 to 73 exepct the 427 Vettes. After smog regulations the camaro couldn't keep up until the third gens. The early vette only had an additional 10 hp because of their better flowing exhuast manifolds and GM's need for the Corvette to have the most power.
Originally posted by madmax
Yea, they did. They sold them right alongside a bunch of 10 year old unregistered 82 Camaro Pace cars, and a few 83 Corvettes with LT1 engines.
unregistered pace cars
what a moron.Everyone is trying to make up stories to make their cars worth more.
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Originally posted by StevenK
Yeah, mine came with the special factory edition time machine, it lets me warp back in time and sell my car at an added value!
Lets see a pic of your RPO codes. I bet it doesn't have "Time Machine High Resale Value Activator" TM1.
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
just thought I'd chime in about the camaros and vettes thing, the only time I know of the camaros being faster are the nickis and yenkos in 67 and 69, and the COPOs in 69. Gotta love the COPO
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
agresive?
aggressive=fast
or as fast as possible
-poping the clutch alot comes to mind(me)
-holding the gas down betwen shifts(power shifting i think)
Car: 1989 RS Camaro
No it didnt really have anything to do with warranting it, or emissions, the transmission doesnt have much to do with emissions anyways. The reason they didnt make the L98 with the T5 is because the T5s torque rating was only 300 ft lbs, and the L98 makes 345 ft lbs of torque. Thats why they only made it with the TPI 305 and T5, because with just that combo, the 305 was at the torque limit of 300, so it was already pushing it.
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Vette vs. Camaro
The 1983-84 Z-28 L-69 could run off and leave a Vette of the same vintage in the dust.
Don't forget the 69-70 Vettes could also have a 350 hp 350 which is the same engine as the 70 LT-1 except a hydraulic cam and q-jet. They would take care of the little 302 Z pretty easy. The LT-1 Vette also had 370 hp in 1970 and the Z-28 the same year only had 360hp. The same 10 hp. seems odd.
I think you could get a LB-9 305 TPI for the first time with a 5-speed in 1986.
Re: Vette vs. Camaro
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
What does the trans have to do with emissions?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
This question gets asked over and over again. The fact is no one on here has ever seen a real documented 350 w/manual transmission car ever.
I think the only way we could believe it is if the RPO sticker has both L98 or B2L codes on it with the code for the T-5. Which I do not know.
There should be a sticky on the main board that says "No thirdgens never came with a 350 and 5spd!!" That's probably the most common and overly asked and discussed thing on this board.
When I joined the board I never asked that question. Why? Becuase someone already had and were told no. It seems like everytime I am on here there is a active thread somewhere asking this question.
When I joined and saw the thread I began using the "Search" key. It proved very usefull. I saw the 15 other threads that had explored the same issue. And even a few where some people argued that they did exist but of course never could prove it.
Ok I am done ranting now.
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
