90-92 Firebird switch panel
Old Jan 11, 2004 | 06:09 AM
MNformula350's Avatar
I was wondering if any 90-92 Firebirds ever came with the panel for the switches above the radio/climate controls, without any holes for switches in them (1LE cars maybe) right now i have one for a 3 switch panel that i put in cause i was gonna wire a fan switch to the fog lights and install a rear hatch release (which i have recently decided against)
Stock my car had just 1 for the rear defroster i plan on putting on a rear window w/o defrost (which looks cleaner in my opinion)and wanted 1 without any holes.
Did gm make one or does anyone have one for sale?
Thanx
Old Jan 11, 2004 | 10:27 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Hmmmmm... Well mine only has the switch for the fog lamps. And it is a vert so no defrost/wiper stuff. So if someone can buy a vert with fog lamp delete (if possible) then it would have no holes in it, which would mean they made one??? This is a conjecture on my part though.
Laters,
Conrad
Old Jan 11, 2004 | 01:29 PM
MdFormula350's Avatar
the lowest i have seen is one, but i guess it might be possible.
Old Jan 11, 2004 | 04:19 PM
Drew's Avatar
There was a panel with no switches, but it still has a flat divot where the single switch would have been.
Old Jan 12, 2004 | 10:04 AM
Thanx Drew i'll have to start looking for that.
Old Jan 13, 2004 | 07:48 PM
Drew's Avatar
Try GM first, if its still available, its probably less than $30. Otherwise if you get desperate the local junkyard HAD one, if its still there I'll snag it for you.
Old Jan 13, 2004 | 07:53 PM
cool thanx, i would appreciate drew just don't make a special trip if you rthere fopr something else fine...thanx again man.
Old Sep 22, 2007 | 05:38 PM
Re: 90-92 Firebird switch panel
Well, here it is 3 Years later, and I am finally getting my non defrost rear hatch glass tinted at work (gotta love working for a custom car shop) and a new rear decklid painted, so.......
Was there ever a switch panel made without any switch holes? And if anyone knows for sure, do you have a gm part #? I have a 90 Firebird parts and illustration manual, but I did not see one in there, but I figure one could have been available for teh 91-92 cars?
Otherwise, I was thinking of using an extra Fog Light switch I have as a manual fan switch, than it would look factory
Old Sep 26, 2007 | 01:02 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would imagine it was possible. As a Formula which did not have ground effects therefore no driving lights, optioned without the rear hatch defog nor the hatch release would not have had any switches.
here ya go, it does exist... try a dealer, tell them what you want it might be available new.
John
Attached Thumbnails 90-92 Firebird switch panel-572-92-1le-interior
Old Sep 26, 2007 | 04:44 PM
Ahhh, so they do make one, sweet!
Thanks for the pic okfoz, I am going to check with my local dealer this week, and see if I can get one. If they are discontinued, hopefully there is one sitting on a dealers shelf somewhere.
Old Sep 27, 2007 | 12:51 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
I think its discontinued. I have an April '95 edition of the '82-92 Firebird Master Parts microfiche and there is no part number listed for the blank buttom panel. The one, two, and three buttom panels were still available back then.
Old Oct 18, 2007 | 11:01 PM
89Formula3's Avatar
Car: 91 Firebird
Transmission: 5 speed
The switch panel on my 91 has no controls at all, no rear defroster or hatch release.
I didn't know that was uncommon.
I'll try and get some pics up.
Old Oct 19, 2007 | 01:34 PM
89Formula3's Avatar
Car: 91 Firebird
Here you go
Old Oct 20, 2007 | 09:29 AM
Nice!
Thanks for the pics, I will be copying those to my Hard Drive when I get home form work.
I really need to get me one of those now, to install when I swap my rear hatch.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
