How much have you spent on your car in the last year
Old Feb 8, 2004 | 10:26 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
Hey guys i was sitting around and decided to check how much i spent on my car this past year.
how much have you spent on your car? minus paint and rims because i know those are big bucks.
i spent $1,544.14 give or take a dollar
:lala: :lala:
Old Feb 8, 2004 | 10:37 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Why shouldn't paint and rims count? It's an expensive specifically for your car.
I haven't spent anything on paint or rims yet.
Anyways, since I bought my current car in mid April, I spent around $2,525 on it not including tax, oil, antifreeze, registration, custom plates, title, show registration, etc.... I have all of my receipts, but don't feel like digging them up to verify, so....accurate to $100+/-.
Expecting to costs to soar to a total of around $8,000 by the end of spring
Total in third gen parts, since I've had 4 third gens is about $3,025 which is not much more. than what I have in my good one alone.
Total parts including purchase of the 4 cars is about $9,275. Damn...could have bought a 4th gen. Oh well, who wants one of those things?
Old Feb 8, 2004 | 10:40 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
3 grand in the restore, well....if you call a 383 a restore.
-Jensen
Old Feb 8, 2004 | 10:49 PM
DC87GTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ383 HSR
Transmission: T-56 6-Speed Manual
Axle/Gears: Ford 9", 3.89 TrueTrac Posi
This is a good question. Since I do not have all my receipts here with me, I can take a good accurate guess at this one.
I have over $3500 in my car just this year. (Over $2000 since a t-56 swap is not technically a restore) Oh yeah, paid $2500 for the car a little over a year ago...
And this is just a low ball guess I mind you. And I am no where near done with the car, well for my standards anyway.
Old Feb 8, 2004 | 11:00 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
for me....probably about 4-5 grand...give or take a few dollars..lol
Old Feb 9, 2004 | 07:51 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Remember guys, this is the History/Restoration board. Costs to mod are irrelevant, only costs to restore to original. I do not know if this was the intent of the original question but can only assume so.
I'll keep keeping a close eye on this thread and if it continues on its current path, it does not belong here.
Old Feb 9, 2004 | 09:32 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
$2600 for the car and about 1500-2K total after that. I am nowhere near finished either.
Old Feb 9, 2004 | 11:26 AM
MdFormula350's Avatar
umm 2,500 is an estimate
1 grand for exhaust
suspension / minor tune up stuff the rest.
Old Feb 9, 2004 | 02:50 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I originally bought my Formula for $1100.00, I had right around 6000 total by the time I had it back to Original... Many mods later I am WAAAY beyond that.
Rebuilt Trans, Engine, Fresh interior, paint etc...
Purchase of Car $1,100.00
Tail lights, including center piece $60.00
Dash Pad $30.00
T-Bar Piece $30.00
Mighty Lift Hood Supports $35.00
Glovebox cover and rear ashtray asmbly $15.75
Glues $10.00
Instrument Cluster & 120Mph Speedo $75.00
CAM, SLP Performance $263.64
Transmission Rebuild and shift kits (Mr Shift "NoYoYo / SysKoKal Kit" $82.00
Transmission Filter $7.99
Transmission Manual shift bar $2.00
Engine parts and rebuild includes new: 40 over pistons, crank, push rods, rockers, oil pump, rebuild kit. $700.00
Brushable gasket sealer (Permatex) $1.45
Spark Plugs (AC Rapid Fire) $32.00
Oil Filter (A/C) $2.50
Spark Plug wires (AC Packard) $40.00
3 gallons Trans fluid 5 quarts oil (Quakerstate) $19.50
Engine Belts $27.00
Air Cleaner Nut $12.33
Hatch Strong Arms, Air Filter, Breather pad, Lighter assm $88.71
Window Switch $10.10
Newer Model Steering Wheel $20.00
Radio box, radio mounts, Door tops, and driving light switch $50.00
Headliner and poster board $25.75
Rear Hatch Shade assembly $6.00
Interior Door Top $5.00
Compete set of seat covers and door fabric $325.00
Spray adhesive and Epoxy $25.00
Muffler Adapter Sleve $8.28
Rear View Mirror (self dimming) $35.00
OEM Black Spray Paint $10.15
One step Aerosol Paint $9.58
Door Hinge (strap) and Pin $35.15
Misc Paint $35.87
1 Front Rotor, Brake Pads, Break Hose, Caliper $76.92
Exhaust from catilitic converter to Muffler $61.05
T-top weatherstrip kit (8 pcs) $171.87
Decals $7.35
Decals $94.68
Decals $24.30
Trunk Liner for speaker board $5.25
Pioneer Front Speakers and 300W amp $202.00
Speaker adapters GM to aftermarket $9.98
Headliner material and panel board $25.75
Sherwin Willialms misc paint stuff $42.60
Air Conditioning Oil $7.99
Front Rotor and seal RH $29.19
Misc Paint & Stuff $241.24
Misc Paint stuff $11.90
Misc Paint stuff $59.94
Extra Hood $125.00
Velcro for seats $20.25
Power Mirriors and Cruise Control switch $65.00
Headliner Material Black $21.98
Ring & Pinion (3.73), Computer Chip, thermostat. $366.33
Speedometer transmission gears for (3.73) $29.00
Rear Differential Cover $31.90
Rear Disk Brake mounting Plates $29.62
Power Mirrior Switch and Positraction additive $39.41
Rear Caliper $109.99
Disk pads, 2 rotors, 1rear caliper, Brake Hose from (S.o. Direct) $265.96
Emergency Brake Release Springs $31.16
Brake Hose Clips $2.58
Ignition Lock Cyl. $15.99
Side view mirrior glass $28.00
Brake Master Cyl $20.94
Brake Bolt $2.95
Center cap Emblem $39.08
John
Old Feb 9, 2004 | 03:56 PM
Mike-92GTA's Avatar
Car: '92 Trans AM GTA
Transmission: Standard Issue
Restored the following: All (OEM) -
Mechanical - Harrison AC compressor, dryer & evaporator; AC Delco alternator, brand new genuine GM Radiator (a real tough find at a decent price), the heater core (OEM?) - Total Cost: $2700 (installed),
Interior - absolutely immaculate - nothing on the drawing boards
Exterior - Complete paint restoration (est $7200)
Old Feb 10, 2004 | 08:05 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
At this point, I rather not know
Old Feb 11, 2004 | 12:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Headers - $100 (buy them and restore them to like new)
Intake - $60 (Again, buy and retore to new condition)
Distributor - $25 (awaiting restoration)
Air Cleaner - $25 (resto cost + new sticker)
Raditator - $150 (Old one popped)
Engine compartment - $50 (retoring to look like new)
IROC swaybars/wonderbar - $10.50
Proudly Showing off engine - Priceless
Old Feb 11, 2004 | 01:37 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
I had to put in a new Delco Battery
Old Feb 13, 2004 | 03:32 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
1,000 so far thats only 2 weeks after buying my new project 89 irocz 5.7 tpi 90,000 orignal mileage every option mainly wear items. and im perticulate ehhe like new turn signal lenses ones in there looked fadded but worked perfectly fine at night just not as brand new looking..
last 3rd gen project
83 z28 fully loaded again
paid 1,700 put 5,000 into it got that 386,000 mile abused motor to run again with full power only thing left when i sold the car was transmission dip stick gasket, plugs and wires due to needing a new carb. and smog pumps and vaccum lines hooked up...but interior and everything looked hot.
Old Feb 14, 2004 | 11:07 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I bought my car 4 years ago from an old lady
The car had 22,000 on it.
I had to put new tires on it because the ones on it hadn't moved in 13yrs.
I had to replace all the hoses and belts. I alos had to replace the radiator-550 Be cool
Never had a problem with it ever, and love it to death
P.S. Its got 33,000
Old Feb 14, 2004 | 03:18 PM
Bwells92RS's Avatar
Car: 92 CAMARO RS
Engine: 305 TBI
Transmission: 700
33,000 miles? You need to get out more. turn off your computer and go for a drive.
Old Feb 14, 2004 | 04:38 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Some of us only take our cars out when its nice and sunny, and warm. Thats where a daily cars come into play
Old Feb 15, 2004 | 03:17 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Well, depends if you mean January 1st, 2004 - February 15th, 2004 or the 2003 year.
2003 - $9k
Most of that was in the engine and transmission
2004
$2k - so far, still have another, oh, 10+ to go
Having it painted, restoring the interior, new brakes, etc...
Old Feb 15, 2004 | 05:55 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Paint job - $3500 CDN = $100 USD
91-92 ground effects - $500
91-92 rims - $300
Tires - $750
MSD Blaster coil - $60
Lots of cash but the car is worth it.
Old Feb 15, 2004 | 07:46 PM
Kevs87Z28's Avatar
Engine: 355 Carb
i ment the entire 2003 year
Old Feb 16, 2004 | 12:37 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
That was in one year..
PS. Just because i am a monkey it doesn't mean that I can't read...
Old Feb 17, 2004 | 04:28 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Hmmm, I guess you can say my Z28 is a resto-mod.
Aside from the cowl hood, I want the exterior and interior to be as close to factory as possible.
For that, paint: @3000
New moldings, and chin spoiler GM: bout $260
New badges, GM: Gift from g/f
others
Stereo, bout $500 so far
Engine $700 in bolt ons
Exhaust $700 (no headers yet)
Suspension $350
Misc like tires, brakes, about $600
Got an SLP posi not installed yet, $100
Alternator, starter, fuel, and oil filters AC Delco From GM
Mostly any other misc stuff i get is genuine GM.
BTW, ive only had the car for 2-1/2 yrs
I figure when i hit the $12-15k mark ill be done. (who am i kidding)
Old Feb 18, 2004 | 08:12 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
alot
@2,000 in body work,other people seem to like running into a red car
@400 in wheels /tires
NEED 2 fronts 16"
let's see @150 in misc stuff
Old Feb 18, 2004 | 09:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm at about $1300 and the car hasn't moved since sept 02.....good times
Old Feb 18, 2004 | 09:42 PM
juggernaut_69's Avatar
Car: 87gta
Engine: dont know yet
Transmission: 700-r4 race prep
Four thousand for the car. Fourty six hundred so far in it, I'm still not done yet and my car has not moved since september of 2001
Old Feb 19, 2004 | 06:52 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Past year being February last year till now... about $5000...
ya I know... too much $ for a car like mine... but that's only 1/2 of what I have into it
Old Feb 20, 2004 | 09:03 PM
ershealy's Avatar
Car: 88 TBI Formula, 98 LS1 TA, 77 400 T
Which one? There are three.
I would have to guess less than $1000 because everything came from the local salvage yard. Besides if I actually made a list it might fall into the wrong hands...my wife's!!
Old Feb 22, 2004 | 11:55 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
1k and climbing!
Old Feb 24, 2004 | 12:10 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I spent something like 7000 dollars on my car but it looks so good now that i dont mind spending alot of money on it.
Old Feb 24, 2004 | 09:39 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
2 oil changes w/Mobile 1 & filter so $72
alignment $39
Rotate tires $50
So $171
Of course that's not counting the LS1/A4, 3200 Yank, PCM wiring harness, LS6 heads, cam, LS6 intake, custome 1 3/4 LT headers, 17inch SS rims & tires etc but that not on the car yet.
I'm not going to count the $4600 to put the car back together after my wife totaled it back in Dec of 01 either.
colton_carlson
Mar 8, 2019 12:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 9, 2015 01:15 PM
