'84 LG4 vs L69
Old Feb 15, 2004 | 11:50 PM
The_Maniac's Avatar
'84 LG4 vs L69
OK, I have a question. What is the true mechanical difference between a 1984 L69 HO vs LG4??
The reason is I have an L69 with a bad engine. I have a possible deal on an LG4. I don't want to loose performance (I want to keep my Z28 with the mechanics at stock spec)....
I've heard rumors that the difference is in any combination from a cam, pistons, heads, and a couple others.
Does anyone know the truth behind it?
Thanks!
Old Feb 16, 2004 | 01:54 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
there are actually alot of differences...ill point out the main ones...
l69 has 9.5 to 1 Compression ratio,lg4 had like 8.5 to 1
l69 has a bigger cam,and flat top pistons,the heads are the same 416 castings LG4's had,the exhaust is another big difference,the manifolds have bigger ports,and the y pipe is a ALOT bigger compared to a LG4
Old Feb 16, 2004 | 11:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider a search, the topic has discussed at length.
JamesC
Old Feb 16, 2004 | 05:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The L69 has...
- higher compression (9.5 vs 8.5)
- better exhaust system
- bigger camshaft
- aluminum intake
- more aggressive carb/ignition settings
- electric fan ('83 anyway...)
- dual snorkel air cleaner (LG4 has 1 small snorkel)
- much stronger "X" connecting rods
Most of this stuff you could take off your L69 when it comes out and drop onto the LG4. It would make an imporvement over a stock LG4.
Old Feb 16, 2004 | 06:47 PM
82RECAROTA's Avatar
Old Feb 16, 2004 | 07:51 PM
The_Maniac's Avatar
I'm looking at possibly getting my hands on an '84 LG4 (I currently have an '84 L69).
From what it sounds like you guys are saying, I could transform an LG4 into 90% of a L69 with relative ease (if I'm following correctly).
Old Feb 18, 2004 | 02:01 PM
Air_Adam's Avatar
If I were you, while both engines are out, I would move all the L69 parts except pistons and rods to the LG4... i doubt it would be hard to reuse the cam and lifters, as long as you can remember which lifter was on which cam lobe.
Old Feb 18, 2004 | 08:50 PM
82RECAROTA's Avatar
PurelyPMD
May 5, 2016 04:57 PM
Night rider327
Oct 13, 2015 01:47 AM
leighgrils
Oct 9, 2015 09:38 PM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
