What is a 1LE ???
Old Feb 16, 2004 | 01:58 PM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
What is a 1LE ???
What does it mean, How do you know if you have it?
Old Feb 16, 2004 | 03:11 PM
bes217's Avatar
search.
basically, in a nutshell, you got better brakes and better suspension. check your rpo codes if there is 1LE then you have it. otherwise you don't.
Old Feb 16, 2004 | 05:09 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Check out this link , scroll down and read the Camaro History.
Old Feb 16, 2004 | 09:20 PM
edge433's Avatar
I don't have it, Thanks
Old Feb 19, 2004 | 06:59 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Some cool options like a gas tank baffle, aluminum spare, no decals/foglights etc... but they are too rare for me to ever want to own one... I couldn't drive the thing without worrying!
Old Feb 20, 2004 | 06:18 PM
Parrydise7's Avatar
There are more than a few 1LE clones on the streets because upgrading to 1LE specs is a fairly popular project. Do a search and you will find quite a bit of info.
Old Feb 21, 2004 | 01:17 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The 1LE package was basically a road racing package... better brakes, better suspension, more lightweight parts (like aluminum spare) etc etc...
Old Feb 21, 2004 | 08:37 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Like me! lol
I have the aluminum driveshaft, baffled gas tank, aluminum spare, posi rear, and the 305 TPI with the non-peanut cam (220hp/300lb/ft) Plus the WC T5. Hopefully a 350 crate will come soon for my TPI setup... but then I have to get a better tranny (not again!!)
Old Feb 21, 2004 | 11:45 AM
edge433's Avatar
Originally posted by aaron7
Like me! lol
My 350 Z28 has all these things too, not sure on the baffled fuel tank. Makes 245hp/375ftlbs. BUT, Still no rpo code of 1LE.
Old Feb 21, 2004 | 09:42 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
1LE commonly ONLY refers to the larger front brakes and the fuel tank improvements.
There are many combinations of options that go along with 1LE, but were not part of it.
And yes there are many examples of ODD combinations that GM made ... so no single rule fits all cases.
The only way to get the 12" front brakes and PBR calipers was to have the 1LE option (1988-1992) or if the car was manufactured for the Player's challenge series in 1988 (they were non 1LE cars with the 12" brakes).
The general assumption was that you had to order a car with the correct grouping of options in order to "qualify" for the 1LE option group. This was true in 80% of the cases. The 20% are the BC4 police options, A4U/R7U Players Challenge cars, the 1989 Anniversary T/A and the odd "mistake" GM made.
Mark.
Old Apr 10, 2004 | 09:40 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Actually... 1LE is an acronym from the Smithsonian borrowed by GM under license that pertains to Russian artwork or more specifically to the Faberge period it stands for "One lucky Egghead"
Old Apr 10, 2004 | 11:43 AM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Get the f*ck out of town!
Old Apr 10, 2004 | 10:36 PM
Air_Adam's Avatar
You serious?
Vintageracer
Jan 10, 2020 05:33 PM
PurelyPMD
May 5, 2016 04:57 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mcgarnicle
Sep 24, 2015 07:18 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
