how to decifer the trim plate codes?
Car: 93 Firebird Formula/79 Trans Am clone
Engine: LT1/LT1
Transmission: T56/4L60E
its off that 82 pace car im looing at
heres a link to the pic:
http://hpiv.net/ipw-web/gallery/82pa...implate?full=1
the codes from what i can tell are:
C 03A 1FP87 L 129889
26G 16L 16U W
AO9 CC1
D S 267735
THANKS!
26G 16L 16U W
AO9 CC1
D S 267735
THANKS!
Car: 4
Engine: 6
Transmission: 5
I don't really know what you're looking for, as the 82 pace cars only came with one trim set. That would of course have been the pace car trim. Either it is a pace car, or it isn't.
Its VIN is xx1FP87 (probably 1G1F...) then 3 VIN digits are left out which are the engine, the year (should be a C for 82), and the check digit; L means it was assembled at the Van Nuys CA plant (the other plant was N, which was Norwood OH); the last 6 digits on that line ar ethe car's production sequence (serial) number. Color 16 upper, Color 16 lower; W is for water-based paint (CA started having very strict environemental emissions issues, and it became very difficult to use solvent-based paint or adhesive out there right about then, so they switched to the water-base latex paint, which is notorious for not holding up well at all). I'm not sure what the rest of it is.
Engine: LT1/LT1
oh im thinking of options and the such
i must be confused, thanks!
will this tell any options that it may have come with?
the vin:
1G1AP8778CL129889
i must be confused, thanks!will this tell any options that it may have come with?
the vin:
1G1AP8778CL129889
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Yea could have asked lol
26G 16L 16U W
AO9 CC1
D S 267735
O3 March (build date)
A 1st week
1fp87 Style number Base
L Can Nuys, cal Plant
26G special code for the pace cars. Dark blue
16l/16u Silver Metallic (upper /lower)
W water base paint
Seats Ao9
CC1 t-tops
Here are the results for your query on: 1G1AP8778CL129889
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Restraint System: Manual belts
Carline Series: Sport Coupe, Z28
Body Type: 2 door coupe
Engine Code: 305 ci V8 LU5 (1982), L69 (1983)
8 is the CHECK DIGIT.
Model Year: 1982
Assembly Plant: Van Nuys
Production Sequence: 129889
Oh I also have whats left of the Build sheet
26G 16L 16U W
AO9 CC1
D S 267735
A 1st week
W water base paint
Seats Ao9
CC1 t-tops
Make: Chevrolet
Model Year: 1982
26G is for Trim Cloth Navy. It's the interior color. Not specific to the Pace Car.
Re: how to decifer the trim plate codes?
The car has black interior and 4 wheel disc brakes. I didnt think black interior was an option with charcoal? Also what does the 18N and the D B S mean ? It is charcoal with T tops
On 82 Firebirds, the exterior color was called Dark Claret metallic. It is a grey color - should be the same on the Camaro.
The 18N should be the interior code, which is charcoal. The N is the trim - like for cloth or vinyl. Not sure what it means.
18N= charcoal vinyl with the custom interior option, the D B S on the bottom of the tag are option codes used by the Van Nuys plant, D=rear spoiler, B=special luggage trim package, (carpet on the rear hatch side trim) S=stereo radio provisions The other numbers 080417 = the first two digits 08= the day of the month the body was started in the build process .with your build date of 08B this equates to August 08 1982 the following numbers 0417 is the body's sequence number for that day of production
Car: 1986 Camaro
Engine: 350-4bbl-Edelbrock Headers
Here is another if someone could help.
1G1FP87H0GN119916
This Camaro is titled as a 1986? I believe its a Sport Coupe, however behind the front license plate bracket "Berlintta (sp)" is stamped into the plastic, could have been changed due to damage.
1G1FP87H0GN119916
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Sport Coupes and Berlinettas shared the same license plate bracket. The front bracket on my '87 Sport Coupe said Berlinetta, even though Berlinettas were discontinued after the '86 model year.
Car: 1986 Camaro
This was stamped into the front nose of the car behind the bracket
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
drb930
Sep 9, 2015 10:53 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
