89 Firebird Formula 5.0, which rear end?
Old Jun 16, 2004 | 03:38 PM
TestyAmoeba's Avatar
Car: 1989 Firebird Formula
Engine: TPI 350 Vette motor
Transmission: 4spd Auto
Which rear end did the 89 Firebird Formula w/5.0 come with? Did it come with a Posi, or standard? Also, what gears do you think came with it? I'm not sure, so I figured I'd ask Thanks again.
Nate -
Edit - It's an auto, forgot to mention that...
Old Jun 16, 2004 | 03:43 PM
MNformula350's Avatar
My 1990 Formula originally was a 305TBI and had a 2:73 peg leg.
I have since swapped in a 350TPI and a 3:73 posi rear.
Old Jun 16, 2004 | 03:49 PM
Did they come with Posi's from the factory at all?
Old Jun 16, 2004 | 03:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some did. Some didn't.
It could have started out life as anything from a 2.73 one-wheel-peel 10-bolt if it's a TBI auto car, to a 3.45 9-bolt if it's a TPI 5-speed G92 car. There are ALOT of possible variations.
I think it doesn't matter what gears it came with, because they might or might not still be there. I think it mostly matters what's in there now. I think the only way to know that for sure is to take off the cover and look. I think the same thing about whether it's a posi or not.
Old Jun 16, 2004 | 04:00 PM
How can I tell what gears they are and if it's a posi or not? Bah...I am such a newb
Nate -
Old Jun 16, 2004 | 04:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Count the teeth on the pinion and divide that by the # of teeth on the ring.
Inside the carrier, which is the big round thing with the gears bolted to it. If it has a pin about ¾" in diameter and some plates and springs and 4 small gears, it's a posi. If all that's in there is a pin and 4 small gears, it's not.
Old Jun 16, 2004 | 04:13 PM
Ok thanks! That clears it up nicely. I don't know if this is any help, but last time I drove it I was on a gravel road and when I floored it both wheels started to spin and she swung out a bit (good times ) as we took off. But I'll take the cover off and have a look anyway, see how it looks inside and what not..
Nate -
Old Jun 16, 2004 | 04:27 PM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
I think if you have rear disc brakes its likely that you have a 9-bolt posi. Not positive on that though.
- Count the bolts. (9 or 10 bolt)
- If it is 9-bolt chances are that its also posi.
If its a 9 bolt:
- Gear ratio tag is at 9-o'clock on the cover (use wire brush)
- Posi tag is at 4:30 (if you have it)
Open it if you want to change the fluid anyways. Its probably due.
Old Jun 16, 2004 | 04:43 PM
Yea, thats why I was thinking of taking it apart anyway. If this helps it has drums in the rear.
Nate -
Old Jun 16, 2004 | 09:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Like RB said, the only real way to know is to pull off the cover and look. That will tell you for certain what gears are in there and wether or not you have a posi.
Might as well change the oil in there anyway, right?
Old Jun 16, 2004 | 10:10 PM
Yup, probably about due anyhow
Old Jun 17, 2004 | 09:43 AM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Look for the passenger side axle tube stamp, it will be facing the front. That code will tell you what the ratio is and if it is a posi or not.
This will help you cross check your gear inspection.
If its a posi dont forget the additive.
Old Jun 18, 2004 | 02:26 PM
Well I just got off the phone a bit ago with her, (my friend who I am buying the car from) and she said she welded the rear end, it did not originally have a posi. She also said it might need to be rewelded a bit.
Is this something I should really be concerned about?
Nate -
Old Aug 16, 2004 | 11:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
id be scared if its welded,
id look for another axle for it,
inside tire on turns will be skipping spinning on the pavement, will eventualyl bust spider or shaft anyways
i wouldnt want to be driving it when that happens!
welding a unit for street daily driver use is not safe and is not smart
but its fine ofr dirt track and demo derby and straight track offroad use though,
if the welds even hold up that is,.,.
but anyways good luck
Old Aug 17, 2004 | 02:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I tore apart a 87 GTA burned and it had a posi. 2.41 rear gear it was a 350 TPI car
Old Aug 17, 2004 | 03:04 PM
TTOP350's Avatar
hectre13
Dec 11, 2023 08:14 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
