92RS vs. 92Z28
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
The badges are differant...
The speedo cluster is differant and the power steering has a sensor on an RS and not the Z... I don't remember what it was for though. The engine/ intake is an obvious change too...
Jason
Jason
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
the sensor in the power steering line was for the PCM to detect when the line pressure went up to determine if it needed to bring the RPMS up to deal with the extra load of the pump. Back to the origional question at hand, I dont think the RSs had the foglamp option either and the grilles may have been different.
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
z28 had a foglight package and grill- RS had a slotted black grill- Z28 had different rims, badges, hood, spoiler, and i beleive the Z had black headlight pockets while the RS is body colored- or is that only the earlier IROCs
Car: 92 Camaro RS
Transmission: T5 manual
In 92 15" wheels were standard on the RS, but 16" Z-28 wheels were avalible as an option. This option also caused a upgrade in the steering box, springs and sway bars.
Car: 92 TA, 91 RS, 98 Tahoe, 95 S10
Engine: 305 TPI, 350 Vortec TBI, 350 Vortec, 4.3 Z
Transmission: 4L60, T-5, 4L60E, T5
plenty of 91-92 rs had 15's. look at the production numbers. 16's were a luxury back in the day. i searched through all of my thirdgen pictures and couldn't find one although i don't have many rs pictures as it is. look a little and you'll see though, most were color coded.
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
My RS has the 16 inch rims...but then again its got the heritage edition package.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by Red92TA
Ok, I stand corrected. I just have never seen a 91 or 92 without 16's.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by camaro05
I just looked at a 91 bird the other day with 305, T5 and 15" rims
Car: '02 Z06
wasn't the high rise spoiler and hood blisters an option on the 91'-92' RS?
And for the record, there is a 91-92 RS near my house with 15" wheels, I heard it drive by once, it sounded exactly like my 305 too..
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
Yep. What he said. 'twas called RPO F41.
Car: 91 Red Sled
Since I own a 91 RS here's what I've gathered over the years;
Only difference between 91 and 92's was the badge on the dash, some wiring harness differences, and a Heritage edition.
Now to speak of the differences between the 91 RS and 92 Z28. Z got 16" wheels standard, RS it was an option. Mine had the L03 TBI (v8) with 15" wheels.
Appearance differences were limited to the front grill, badges, rear spoiler. Now there are a LOT of differences with the powertrain options and the interiors were slightly different. The RS never came with a 145mph speedo, only 110
Kandy, the RS's COULD get black headlight pockets!
Also, the suspension were different, same with rear, driveshaft option etc. The B4C option gave the RS model everything the Z had but with an RS "shell" so I recant on that no RS's with a 145mph speedo because those had em.
.Kandy, the RS's COULD get black headlight pockets!
Car: 91 Red Sled
Originally posted by scottmoyer
Only with the Heritage Package. All other RSs were body colored.
Originally posted by JPrevost
Right, but the Heritage Package wasn't limited to Z's so RS's could have black headlight pockets.
Car: 91 Red Sled
Originally posted by vejatabul
since 1989 the rs was the base model camaro. they discontinued the sport coupe after 1988.
Car: '02 Z06
QUOTE]Nope, SC had it's last year in 86, 87 was the LT and 88 was the RS till 92.[/QUOTE]
Sport coups last year was 88, not all 87s were LTs and Rs was only available in CA, Florida, and Texas in 88 and as only a V6 model.
Car: 91 Red Sled
I read that in the tech data but have yet to find any actual information (owners of cars) that comply with those findings. Example; NJ buddy of mine has an 88 RS with the L03, he's not the only one. So explain to me how the only RS's those years were found in 3 states and only v6 option. I've also never seen any 87 or 88 SC models, none, and I've seen a lot of thirdgens in the junkyards and over the years.
Car: '02 Z06
I dont know what else to believe
Also, the last year for the SC was 1988. It was available with the shorty spoiler. The RS debuted in Ca in 1987 as a V6 and was available in only a couple colors. In 1988 it became available in TX and FL. It was available to the masses from 1989 to 1992. Since this was originally questioned about the difference of a 92Z and a 92 RS, I don't see where that info is relevant.
Apparently the 16inch wheels triggered the F41 suspension (or vice versa)which also required the V8. However, the V8 was available without F41 and 16inch wheels. I saw at least one new and several stock when only a few years old. But, it seems V8 91/92 RS are far more common with the 16s than with the 15s. What's hard to tell are the Pre-91 V8 RS cars when you see one drive by ..unless you are close enough to hear
Of course, these things are getting old now and can have anything changed.
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
I have yet to see a 91-92 RS with 15" wheels. My 91 had the wide 5 spoke wheels...which were 16's. I believe the last time they used the 15's was in 87. Actualy I think the RS always had the 16" wheels, it was the base model camaro that had the 15" 5 spokes.
my first 3rd gen was an 88 sc with an lo3.
Car: 1991 Camaro Z28
Not to keep getting off the subject, but I just wanted to confirm the 88 Sport Coupes existing. My best friend has one, where the RS badges would be on the GFX, it had an emblem that said CAMARO instead, and the same on the bumper too. And it had the short wing spoiler that looks kinda like a miniture of my 91 z28's wing. This car also had an L03 from the factory with the auto, and the 15" aluminum wheels, and the slotted grille like the 91-92 RS. The car was a solid color when he got it, but we believe that the GFX were silver from the factory. Hope this helps
I just got a 91 RS Convertible with the 305 tbi v8. It to has the 16 inch wheels, I am about to switch the steering box from my 89 IROC to the RS. My question is should my RS already have it???
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Originally posted by ES87iroc
Most all v8 rs cars had 16" wheels. I have only seen two that had the 15's on it. Every v6 car I have seen had 15" wheels.
the one sitting in my driveway has 15" wheels
and uhhhh... i've actually RARELY seen an RS with 16" wheels...
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by Dizturbed One
you can make that 3 now...
Re-read the post and try again.
Car: 91 Red Sled
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I re-read your post and also am suprised at what you've seen. My 91 RS had the 15" wheel's and the 305 TBI. Make that 4?
As I posted, most all v8 rs cars I have seen had 16" wheels originally. Did I say all? No, no I did not.
Car: 91 Red Sled
And your point is? Disturbed felt it nessicary to post that his car has 15" wheels, however his car is a v6 so the point is moot.
Now I didn't check those cars RPO codes but when it's got 15" stock wheels it's not often that they originally came with 16's!
Did I say you said all? No, no I did not.
[QUOTE]Originally posted by Kandied91z
have a steering box? yes
Well I think that I have figured that out already since somehow when I turn my steering wheel my front wheels turn. SO it looks like I will have to change the box. Thanks for your help.
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Car: 1992 B4C/1LE/L98///1992 Z28/Heritage Edition?/L98 white with Black stripes///1992 Z28 Convertible Heritage Edition, L03 with RMT, white w/Red Stripes///1992 RS, Heritage Edition, white with red stripes
Engine: L98 x 2, L03, V6
Transmission: 4L60 x 2, 5 Speed x 2
Also noticed that my two 92 Z28's have the hood blisters on them, my two RS's do not.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
wrong. my friend's '87 IROC 5.7L has t-tops
In 1987, which was the first year for the 350 L98 (option) you COULD get t-tops....because from 1987-1989, the L98 produced less torque. Starting in 1990, you COULD NOT get an L98 equipped IROC (90), Z28 (91-92) because they produced more torque and would twist the bodies.
Hope I cleared that up for ya
Engine: L98, Hemi 6.2
shawn you are right. But in 87 the had 330lb of tq and in 92 the L98 had 345lbs of tq.. Not much of a diff at all.. But they learned from there mistakes from 87-89 that ppl that abused the L98 with ttops had lot of body issues... So then they stopped in 1990
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
My two cents!
yea i have an 88 sc camaro. its the 2.8 it is factory red with grey gfx, now this spoiler you guys are talkin bout, i dont know what was up but something was of on most of there like it did not line up in the back .. almost like it was not aligned correctly realy a poor job ,,,im not sure its cause of the power setup that closed yer hatch tight, but sumthing was wrong.. i did like that wing though it was better then the one on my 91 r/s .. i dont like my thrid break light being in the rear window like that.. looks weird
