Prototype Thirdgen Intakes
Old Mar 24, 2006 | 08:56 PM
  #51
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Yup a shame they cut it up, but I guess they only keep the rare one-off stuff. This was "just" an RS with cool stuff on it. Not like the 1-off detroit autorama stuff.
They should have made 50 or 100 of them.
Mark.
Old Apr 1, 2006 | 12:31 AM
  #52
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
How do you know it was cut up? Last I heard, it was in the GM Showroom.
Old Apr 1, 2006 | 12:34 AM
  #53
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
I thought there was still 1 left myself from what Ive read and the magazine articals. I copied this from another site. "edit: actually maybe his site ^ I didnt notice his name :P"
"Here you will find the 1992 Collectors Edition Camaro list. In this list you will find pages pertaining to the The 25th Anniversary Special Edition Prototype which was what Chevy was proposing to produce instead of the Heritage Edition. It was to be called the "Collector's Edition" , the Camaro that never came to be. Consisted of a Corvette 275 Horsepower engine, Corvette ZF 6-speed transmission, etc. It would have been one great Camaro. Learn about it here and why they DESTROYED them all before production except for 1."
Anywho just thought id add my 2 cents.
Jeremy
Old Jun 29, 2014 | 11:35 PM
  #54
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: Prototype Thirdgen Intakes
Massive Update: First post and pictures are the originals on a new host not on thirdgen proper. Also has comparison to stock TPI in them.
Old Jun 29, 2014 | 11:36 PM
  #55
3.8TransAM's Avatar
This is the last of all original photos now linked for easy viewing
Old Jun 29, 2014 | 11:41 PM
  #56
3.8TransAM's Avatar
New pictures 06-29-14
Old Jun 29, 2014 | 11:45 PM
  #57
3.8TransAM's Avatar
Old Jun 30, 2014 | 12:01 AM
  #58
3.8TransAM's Avatar
All photos added.
Part numbers on plenum is:
10077151A
8DE86 I believe is the casting date of Dec. 8th 1986
Part number on intake base is:
10088002A5
Also has 08197 as well
Runners marked:
A on upper plenum section
B on forward paired port
C on rear paired port
This is also the only documented set of this TPI intake on the internet and it now resides here at thirdgen.org.(would love seeing the other owners do something similar) I hope you enjoy it even with my sub par photo skills.
I know of two complete intake/plenum/runner setups and one that is intake and runners only. From a couple folks there may be another complete intake setup that sold on ebay a few years ago. 89onlyZ51 on corvetteforum has the other complete setup. C409 on corvetteforum has the intake and runner setup minus the plenum.
All available threads with any information or pictures on the internet:
https://www.thirdgen.org/techbb2/sho...hreadid=292194 Original thread where I found the intake
https://www.thirdgen.org/forums/tpi/...e-intakes.htmlFirst post looking for more information
http://forums.corvetteforum.com/c4-p...intake-fs.html Intake base and runners for sale
All pics and most information are in this thread itself(aka the one you are reading):
https://www.thirdgen.org/forums/hist...n-intakes.html
This is all the information I can locate on the internet and talking to the two other people who have this same setup. If anyone else has anything to input on design/factory/prototype/etc, please contact me.
Jeremy
Old Jun 30, 2014 | 10:04 PM
  #59
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
That is so cool. I wonder if that was supposed to go on the "new for 87" 350 TPI setups. It would have been soooo much better in the f-body vs fox body wars...
It also looks to have two right side runners like SLP has been doing for the last few years and a lower corvette intake.
Old Jul 1, 2014 | 08:25 AM
  #60
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It could have even have been a proposed OTC Dealer conversion, but when SLP stepped in they said why bother.
It is pretty cool nonetheless. I know the runners I have on mine that are just 1/8" larger Diameter increase the area by about .5 sq inches. or about 10% I would bet those increase the area of about 33% or so...
Old Jul 1, 2014 | 08:51 AM
  #61
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
If you are still looking for someone with contacts at GM to help figure out the stories on the prototypes, you might check over at MiFbody.com and look up Brian Meissen (owner of the site). He's a Senior IT Auditor at GM and seems to have many contacts there. (He even managed to get the 2014 Z28 on display at the 2013 MiFbody Meet & Greet BEFORE it was released to the press.) I'm thinking that if he can't offer any insight, he might know someone who can.
Brian's contact page:
http://www.mifbody.com/vbulletin/member.php?193-meissen
Last edited by 1991_RS; Jul 1, 2014 at 08:52 AM. Reason: added brian's contact info
Old Jul 1, 2014 | 09:21 AM
  #62
okfoz's Avatar
I wonder if Scott Settlemeyer {sp?} would know
Old Dec 16, 2014 | 03:27 PM
  #63
89onlyZ51's Avatar
Car: 1987 Corvette Conv
Engine: Callaway Twin-Turbo
Transmission: Doug Nash 4+3
Axle/Gears: 3.07 Dana 44
Reviving this old thread because I just came across it looking for info on my intake. As Jeremy says, I'll have to get some good pictures of it uploaded for you all.
What I find VERY interesting is that my base has the same part # as Jeremy's - 10088002 AS with 06307 cast below that, BUT my plenum has part # 14081006, which is the same as the production 85-88 TPI plenum. Also, mine does not have the date code cast as numbers/letters. Mine has the little "clock dial" symbols. Even cooler is that the year is 87 but the other two dials are set to zero (I think hard to see the plenum is still mounted to the runners/intake). The part # and date on the plenum lead me to believe they were pretty darn close to going to production with these!
Old Dec 16, 2014 | 05:27 PM
  #64
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
subscribing
Old Dec 21, 2014 | 10:29 PM
  #65
3.8TransAM's Avatar
From other conversations, I'm willing to bet u have a stock plenum that was cut to fit the runners.
Old Dec 21, 2014 | 11:40 PM
  #66
TTOP350's Avatar
Still read this thread now and then. Great info!
Old Dec 22, 2014 | 05:35 PM
  #67
89onlyZ51's Avatar
At first glance, I thought it was a different casting, but upon closer inspection, you're right - it does appear to be a modified stock plenum. It's very well done, though, and not just opened up like the one that was for sale on corvetteforum. I can only seem to upload 1 picture. I'll try more later.
Old Dec 22, 2014 | 05:39 PM
  #68
89onlyZ51's Avatar
Here's another.
Old Dec 23, 2014 | 01:00 PM
  #69
89onlyZ51's Avatar
Here are a couple of the base.
Attached Thumbnails Prototype Thirdgen Intakes-wp_20141222_007a.jpg   Prototype Thirdgen Intakes-wp_20141222_009a.jpg
Old Dec 29, 2014 | 11:59 PM
  #70
3.8TransAM's Avatar
The few, the proud, the GM large tube runners.
Old Dec 30, 2014 | 12:02 AM
  #71
TTOP350's Avatar
Has anyone put one of these on a flowbench?
Old Dec 30, 2014 | 06:20 AM
  #72
PurelyPMD's Avatar
Engine: LB9
Does anybody have one of these they want to sell?
thebosspontiac@hotmail.com
Old Dec 30, 2014 | 09:33 AM
  #73
TTOP350's Avatar
Be ready to spend some $$$$$$$$$$$$
Old Dec 30, 2014 | 10:19 AM
  #74
okfoz's Avatar
Honestly you would be better off getting something else in reality. Bang for the buck there are probably better alternatives...
John
Old Jan 21, 2015 | 05:04 PM
  #75
3.8TransAM's Avatar
John
I don't know about that, if you wanted to keep TPI, I'm not thinking you will beat this.
Old Jan 22, 2015 | 08:29 AM
  #76
PurelyPMD's Avatar
Engine: LB9
Well, if one becomes available, I'd be interested.
Old Aug 2, 2018 | 08:55 AM
  #77
TTOP350's Avatar
Originally Posted by Mark_ZZ3
That engine in the picture ended up going out of country in a crate when the car was torn down. I've tried - unsuccessfully - to buy the runners off it. I was actually trying to just get pictures of the thing, inside and out. But no luck on that front either.
Mark.
Back from the dead
I was talking with a guy that I made a recent Ebay purchase from and he has info on who built the runners for the 92 RS Heritage prototype... I'll reach out to him and double check the info, he said they would still make them but are very pricy..
Old Aug 3, 2018 | 03:22 PM
  #78
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Originally Posted by Sleeper_Z
The 92 Heritage collectors edition engine. I know the runners are different but its possible that they changed a few things in the process.
I want one, looks bad A$$
Old Aug 5, 2018 | 08:41 AM
  #79
PurelyPMD's Avatar
Engine: LB9
Define pricey?
Old Aug 6, 2018 | 06:24 AM
  #80
TTOP350's Avatar
Define pricey?
Keith told me that when he inquired it was 2k. I thought that was a bit up there buuuuuuuuuuut..
Old Aug 6, 2018 | 02:11 PM
  #81
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
I wonder what the price would look like if he had a handful of guys willing to commit to buying sets or pre paying for them
camaroyoungster
Jan 4, 2015 07:01 PM
1989GTATransAm
Jan 29, 2012 11:53 AM
okfoz
Dec 26, 2008 10:36 PM
Gambit69
Alternative Port EFI Intakes
20
May 27, 2007 06:39 AM
3.8TransAM
Apr 11, 2006 01:10 PM
