Back to V-Belts
Old Sep 8, 2005 | 10:23 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
Back to V-Belts
i have Serpentine in my 86 and it origionally had V-belts. i have the old setup and i would like some help on where the brackets go. when i took it off it was very confusing. the serpintine was very simple. any help would be GREATLY appreciated
Old Sep 8, 2005 | 11:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My '83 Z28. Same brackets it came with. The belt in the center (back groove of the WP pulley) loops only around the WP and the crank pullies. Its not factory. Its a 36" belt if you decide to try it though. You can't use that with AC though.
Anyway, enough rambling from me... here you go.
Old Sep 9, 2005 | 08:43 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Unfortunately the 83 is different than 86...
John
Old Sep 9, 2005 | 09:08 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
John
It is? The V-belt setup on my '84 T/A is the same as my friends '87 IROC with the exception that the alternator bracket is revised to accept the smaller style alternator.
Old Sep 9, 2005 | 10:04 AM
okfoz's Avatar
it is similar: I guess because I have AC & the Air pump.
This is my 87 but it is just like the 86 on my friends 86 T/A.
John
Old Sep 9, 2005 | 10:31 AM
Transmission: WC T5
thank you very much. i have a new 305 to replace my tired one. the new engine came with serpintine and has centerbolt valve covers. when i switch should i use the V-Belt or serpintine?
Old Sep 9, 2005 | 10:41 AM
okfoz's Avatar
SERP for sure, You will have to re-route the wires for the A/C and the Alt, but worth it IMHO...
If you want to get rid of the serp stuff I might be interested for the right price.
John
Old Sep 9, 2005 | 11:06 AM
Transmission: WC T5
thats all right. i think ill hold onto it lol. im only going back to V-Belts because the Alt died and i cant afford a new one. plus the hookups for my air injection pipes fit better with V's so until i drop in the new engine from an 88 IROCZ then i stay Vbelts i guess. altough i will miss the conveniance of serpintine
Old Jul 4, 2006 | 07:05 PM
Transmission: WC T5
wow i remember this post. never did change back to vbelts. lol. i guess i said f- it
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
