firebird rpo codes
Car: 83 z28
Engine: 305 for now
Transmission: 5 speed
firebird rpo codes
not positive if this is the place to post this but does anyopne know where the rpo codes on a firbird are? I,ve looked over my entire car but can,t seem to find them, any help would be apperciated. Thanks in advance.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
85 they were in the center console, if not there your out of luck, as I do not think even the dealers can get a hold of them.
John.
John.
Car: 83 z28
Engine: 305 for now
thanks, thats where i thought they were but their gone, ahh well the car is pretty much a base car but was just curious.
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
There's another spot somewhere...I have one in the center console sealed under plastic and tape (found it when I was looking around one day). However, the thing is I found a piece of another RPO code sheet (had a few of the same codes as my center consol one did) on yellowed paper on my floor once. So you might find it underneath a seat or something somewhere too.
THats commonly called the build sheet, it is the piece of paper that follows your car around in the assembly plant and is discarded about the time your carpet was installed during the assy process.
John
John
I heard you can get the build sheets or window stickers from the Pontiac historical society or something like that. I gotta do that too because the sheet is gone in my car too.
I have not looked into it yet but I heard that.
Re: firebird rpo codes
84 and older on all cars is when there was a SPID label at all
before 84 you are SOl unless you are lucky as hell and find a build sheet in it
i completely stripped out my 82 WS7 and founf nothing at all so it will never be proven to be what it is
ever
screwed
if you hvae an 85-up then you had a chance if it hd the lavel still in the glovebox lid, but if not then you gotta hope for a buildsheet in the car somewhere., if not then good luck.,.,
unless pontiac can help..
but i dunno about that..
does anyone ?
i know id like to know about this historical thing ?
good luck
1 Post
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi All,
I found both copies of my RPO code sheets when I replace the carpet in my 82 Bird back in 1998. One was in the trunk area and the other was underneath the console. The one underneath the console is in the best shape.
hectre13
12-11-2023 08:14 AM
